Dashboard tooltip coving menu item
Anyone else getting this? There is a tooltip for the menu items on the left that pops up when you hover over dashboard items. Annoyingly, I have to click just around the edges of the tooltip as clicking the tooltip itself does not open that menu item.
It’s not a critical issue, but it is very annoying on a daily bases.
Your side-bar icons are not standard. Do you have a custom side-bar plugin installed?
Ah yes - I have the Material You theme active. It seems this shifts the tooltip from the right to hovering over the icons. I’ll see if there is anything posted to that themes git.
You can always disable the Material You theme temporarily to identify if that is the source of your issue.
thats what I’ve just done. It does indeed shift the tooltip which isn’t really desirable.
You should be able to edit that line out in the theme yaml.
TBF - I think it’ll be better letting the author know as I don’t want to be editing the theme every time an update is released.
