Dashboard views missing on IOS companion app
Good morning,
I have a simple dashboard (with bubble card, but I have the same behaviour with no cards) which has a strange behaviour on the companion app. The views header shows up briefly when the dashboard is loaded or refreshed (picture 1), but disappear immediately. I tried accessing the dashboard directly in Safari and everything looks OK (picture 2).
I could not see anything like this discussed.
Would anyone have an idea what could be the reason?
Hi Christian, are you referring to the same URL and/or are you using a modified theme?
Hi Nick,
thanks for your quick answer. In fact on companion app, I use the bubble theme, while on safari, this is the default one.
Your question brought me to change the theme on the companion app, and it work! The culprit seems to be the bubble theme. I’ll investigate this further…
Many thanks.
