Hi everyone,
I’m working on a smart mirror dashboard where I’m trying to display warnings directly pulled from a JSON file. These warnings include motion notifications (with an image) and other types of alerts like errors or info messages. The goal is to display this data in real-time, cleanly organized.
What I’m Trying to Achieve
- Display motion notifications with location, timestamp, and an associated image.
- Show other notifications (e.g., errors or info messages) sorted by timestamp, limited to the most recent five.
- Directly process the JSON data in the dashboard without relying on additional sensors or helpers.
JSON Setup
The JSON data looks like this:
"notifications": [
"type": "motion",
"timestamp": "2024-12-20T15:30:45",
"source": "Front Camera",
"file_url": "https://example.com/image.jpg"
"type": "error",
"timestamp": "2024-12-20T14:00:00",
"description": "Battery low"
"type": "info",
"timestamp": "2024-12-20T13:45:00",
"description": "New firmware available"
The JSON is directly loaded into the dashboard card without intermediate processing.
My Current Card Code
Here’s the YAML configuration for my warning card:
- type: vertical-stack
view_layout:
grid-area: main1
cards:
- type: markdown
title: Warnings
content: >
{% set notifications = state_attr('sensor.notifications', 'notifications') %}
{% if notifications %}
{% set motion_notifications = notifications | selectattr('type', 'eq', 'motion') | list %}
{% set other_notifications = notifications | rejectattr('type', 'eq', 'motion') | list %}
{% set sorted_other_notifications = other_notifications | sort(attribute='timestamp', reverse=True) | slice(0, 5) %}
### Latest Motion:
{% if motion_notifications %}
{% set latest_motion = motion_notifications[-1] %}
_**Location:** {{ latest_motion.source }} - **Time:** {{ latest_motion.timestamp.split('T')[1].split(':')[:2] | join(':') }}_
{% else %}
No motion detected.
{% endif %}
### Other Notifications:
{% if sorted_other_notifications %}
{% for notification in sorted_other_notifications %}
**Date:** {{ notification.timestamp.split('T')[0] }}
**Message:** {{ notification.description }}
{% endfor %}
{% else %}
No other notifications available.
{% endif %}
{% else %}
No notifications available.
{% endif %}
card_mod:
style: |
ha-card {
background: rgba(64, 64, 64, 0.7) !important;
color: white;
padding: 16px;
The Problem
The card keeps reloading (flashing) repeatedly. Based on my debugging, I suspect the issue lies in this line:
When I remove the slice(0, 5)
part and display all notifications, the card works fine without reloading.
My Questions
- Why does sorting or slicing the data seem to cause this reloading issue?
- Is there a way to fix this while still displaying only the five most recent notifications?
- Are there more efficient ways to handle this kind of data processing directly within the dashboard?
Thank you in advance for your help and suggestions!
