Dashboard works differently Internal vs External
I apologize if i don’t use the official terms, I’m still pretty new to HA. I am running HAos on a raspberry pi5. I made a dashboard and it works great. I am using the default theme currently, and default card types. I set up the app to use a ZeroTier VPN for access when I’m away and need to do something. I am running into an issue though when external. I can turn things on/off with the toggles directly on the cards, but I can’t click on them to bring up other options (e.g. dimmer, color change, etc.) like when I’m internal. Same dashboard, both in the app. Also, I can’t switch dashboards or go to settings (or anything else in the left bar). Any idea what might cause this or how to fix it?
Hi, welcome to the forum!
Are you also using different devices to access HA internal and on the road?
It should be the same, only when using SSL you cannot use non-secure connections.
Same phone, same app. The only difference for me is to connect through the vpn directly to the WiFi. No error messages or anything.
I have the exact same behavior on a install in X86 Hardware.
I tested so far:
2 Differnent phones, with app or in browser.
clear browser cache and new login.
reboot HA multiple times and on latest updates as time of writing.
I also tried it with a Linux PC using Chrome and Firefox.
Everytime the same result .
What i additionaly noted is that no graphs are loading and the ui is overall verry unresponsive.
Any Idea how i can provide some usefull information for what is happening?
greetings
primsam
