I understand the overview/automatic (original-states) dashboard is special.
But it appears to bring in card types specific to each entity. If I fill in a manually (start from scratch) dashboard, one way to do so is with custom auto-entities. But that requires (I think) that I pick a card type.
Is there any way to do something similar (e.g. auto-incorporate entities) and have them use a card appropriate to their domain, like the overview dashboard does?
The closest are types like glance, entity and tile, but those are not nearly as robust.
This is as close as I’ve been able to get so far with auto-entities and templating. It does allow me to look at attributes of an entity and pick the card type, which is what I want. What it doesn’t do is make it very easy to arrange sizing (e.g. thermostats bigger than buttons), though it does adjust row height to the largest in a row, all columns are the same size. And of course you can not drag and drop any arrangements since it’s all generated by the sort order of the auto-entities.
But in case it’s useful (or in case there is a simpler way) an example (you clearly might want to adjust the if’s and types used. This is one view of a dashboard:
