DashPad: an iPad kiosk browser that shows your dashboard only when someone's in the room
https://www.youtube.com/watch?v=QXoBq97Vv_8
I wanted to use an old iPad as my Home Assistant dashboard, but none of the existing options fit. The kiosk apps I found did far more than I needed, and the alternatives were leaving the screen on all day or adding another presence sensor to the room. So I built a small kiosk browser that uses the iPad’s own front camera instead.
It shows your HA dashboard full screen when someone is in the room, and switches to an idle screen when nobody is.
How presence detection works
Every few seconds the front camera starts, waits a couple seconds for auto-exposure to settle, grabs a single still frame, and runs it through Apple’s Vision framework on the device. It checks luminance (to know when the room is dark) and whether a person is in frame. The frame is processed in memory and discarded immediately: nothing is written to disk, nothing is logged, nothing leaves the iPad. The camera indicator is on for those few seconds per sample, not continuously. The sample rate is configurable, with a separate slower rate for dark conditions.
Privacy
The app makes no outbound requests of its own. No analytics, no telemetry, no accounts. The only thing touching the network is the web view loading the URL you give it. The full source is public, so you don’t have to take my word for any of this.
Licence and pricing
The source is on GitHub, and personal, non-commercial use is free if you build it yourself. There’s also an App Store build from the same code: one-time purchase, no subscription, no in-app purchases.
Feedback I’m after
I’ve only tested this in my own house, so I’d love to hear how presence detection behaves in yours:
  • Other features you would like to see implemented
  • Rooms where it misses you (backlit windows, low light, iPad placed high or at an angle)
  • Sample rates that work well for you
  • Which iPad model and iPadOS version you’re running
I hope you like it! :smiley:
How to hide the clock and battery in header? Is it even possible? Thanks for the app.
I’m afraid it’s not possible at the moment, I never noticed them! However, it should be easy to fix so I’ll add it to the next build :slight_smile: . Thanks for the suggestion and for downloading it!
Thanks. One more thing, I have a battery automation and a switch that turns off charging at 80% and turns charging on at 20%. It doesn’t work with DashPad. Maybe I’m asking for too much?
I fixed the status bar issue: now it never shows in idle mode, and you can disable it completely for active mode in settings. I also added support for iOS15, so Apple is taking a bit longer than expected to review it (even the beta version :downcast_face_with_sweat:).
Regarding the battery automation, yes, that’s exactly what I have, but you don’t need DashPad for that. You can configure it directly in your home assistant.
Thanks for your feedback!
New version is live now :slight_smile:
Works great. Thank you. Regarding the battery automation, I figured that out too :slight_smile:
Keep up great work.
