I have a problem with data recording. I’m not sure if it’s a Home Assistant problem, one from Grafana or one from ESPhome.
Initial situation:
I query two SDM72 via -platform: sdm_meter
. On one, all available parameters are recorded. On the other one (for test purposes - to keep the query time as short as possible), only the voltage and current of L1.
Error description:
Very few measured values are displayed in Grafana. For test purposes, I record a value every three seconds. All measured values are displayed in the ESPhome logging console. It is also indicated that they are transmitted to Home Assistant.
Large gaps are visible in Grafana.
These gaps are not present in Home Assistant (History). However, I do not know whether they have really been recorded/transferred/saved or whether Home Assistant is “cleverly” interpolating.
My own ideas and observations:
If the values change regularly (as with the voltage, which is transmitted with two decimal places), continuous graphs appear in Grafana. If they have a constant value for a longer period of time (such as the current when the instantaneous water heater is not used, i.e. it is zero) then gaps appear in Grafana.
Of course, I can use tricks to fake the values (fill “zero” in the query or “Step After” in the line interpolation). But that is not how it should be.
I would first like to check exactly what data Home Assistant receives and where it stores the data.
Log of ESPHome - Not the same Time Period but it results in the same Effect.
ESPHome Configuration
packages:
common: !include .common.yaml
esphome:
friendly_name: "ESPHome Modbus"
min_version: 2024.6.0
name_add_mac_suffix: false
project:
version: dev
esp32:
board: esp32-c3-devkitm-1
variant: ESP32C3
framework:
type: esp-idf
i2c:
sda: GPIO4
scl: GPIO3
# Example configuration entry with 2 sensors and filter
# wireguard:
# address: 192.168.14.129
# private_key: !secret wg_private_key
# peer_endpoint: !secret wg_endpoint
# peer_public_key: HDOFIvQkrU39eDT6uTANbcbqs8JGp17l+RUutBc4xho=
# # Optional netmask (this is the default, no outgoing traffic
# # will pass through the tunnel if omitted)
# netmask: 255.255.255.0
# # Optional endpoint port (WireGuard default if omitted)
# peer_port: 58518
# # Optional pre-shared key (omit if not in use)
# peer_preshared_key: !secret wg_shared_key
# # Optional list of ip/mask (any host is allowed if omitted)
# peer_allowed_ips:
# - 192.168.14.0/24
# - 0.0.0.0/0
# require_connection_to_proceed: True
# # Optional keepalive (disabled by default)
# peer_persistent_keepalive: 25s
# binary_sensor:
# - platform: wireguard
# status:
# name: 'WireGuard HIG Status'
# text_sensor:
# address:
# name: 'WireGuard Address'
uart:
tx_pin: GPIO21
rx_pin: GPIO20
baud_rate: 9600
data_bits: 8
stop_bits: 1
parity: NONE
modbus:
flow_control_pin: GPIO0
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
device_class: ""
- platform: sdm_meter
address: 10
phase_a:
current:
name: "Durchlauferhitzer L1 Strom"
voltage:
name: "Durchlauferhitzer L1 Spannung"
active_power:
name: "Durchlauferhitzer L1 Wirkleistung"
power_factor:
name: "Durchlauferhitzer L1 Power Factor"
apparent_power:
name: "Durchlauferhitzer L1 Scheinleistung"
reactive_power:
name: "Durchlauferhitzer L1 Blindleistung"
phase_angle:
name: "Durchlauferhitzer L1 Phasenwinkel"
phase_b:
current:
name: "Durchlauferhitzer L2 Strom"
voltage:
name: "Durchlauferhitzer L2 Spannung"
active_power:
name: "Durchlauferhitzer L2 Wirkleistung"
power_factor:
name: "Durchlauferhitzer L2 Power Factor"
apparent_power:
name: "Durchlauferhitzer L2 Scheinleistung"
reactive_power:
name: "Durchlauferhitzer L2 Blindleistung"
phase_angle:
name: "Durchlauferhitzer L2 Phasenwinkel"
phase_c:
current:
name: "Durchlauferhitzer L3 Strom"
voltage:
name: "Durchlauferhitzer L3 Spannung"
active_power:
name: "Durchlauferhitzer L3 Wirkleistung"
power_factor:
name: "Durchlauferhitzer L3 Power Factor"
apparent_power:
name: "Durchlauferhitzer L3 Scheinleistung"
reactive_power:
name: "Durchlauferhitzer L3 Blindleistung"
phase_angle:
name: "Durchlauferhitzer L3 Phasenwinkel"
frequency:
name: "Durchlauferhitzer Frequenz"
total_power:
name: "Durchlauferhitzer Gesamtleistung"
import_active_energy:
name: "Durchlauferhitzer Gesamtwirkarbeit"
export_active_energy:
name: "Durchlauferhitzer Gesamtwirkarbeit Export"
import_reactive_energy:
name: "Durchlauferhitzer Gesamtblindleistung"
export_reactive_energy:
name: "Durchlauferhitzer Gesamtblindleistung Export"
update_interval: 3s
address: 11
phase_a:
current:
name: "Werkstatt L1 Strom"
voltage:
name: "Werkstatt L1 Spannung"
active_power:
name: "Werkstatt L1 Wirkleistung"
power_factor:
name: "Werkstatt L1 Power Factor"
apparent_power:
name: "Werkstatt L1 Scheinleistung"
reactive_power:
name: "Werkstatt L1 Blindleistung"
phase_angle:
name: "Werkstatt L1 Phasenwinkel"
phase_b:
current:
name: "Werkstatt L2 Strom"
voltage:
name: "Werkstatt L2 Spannung"
active_power:
name: "Werkstatt L2 Wirkleistung"
power_factor:
name: "Werkstatt L2 Power Factor"
apparent_power:
name: "Werkstatt L2 Scheinleistung"
reactive_power:
name: "Werkstatt L2 Blindleistung"
phase_angle:
name: "Werkstatt L2 Phasenwinkel"
phase_c:
current:
name: "Werkstatt L3 Strom"
voltage:
name: "Werkstatt L3 Spannung"
active_power:
name: "Werkstatt L3 Wirkleistung"
power_factor:
name: "Werkstatt L3 Power Factor"
apparent_power:
name: "Werkstatt L3 Scheinleistung"
reactive_power:
name: "Werkstatt L3 Blindleistung"
phase_angle:
name: "Werkstatt L3 Phasenwinkel"
frequency:
name: "Werkstatt Frequenz"
total_power:
name: "Werkstatt Gesamtleistung"
name: "Werkstatt Gesamtwirkarbeit"
name: "Werkstatt Gesamtwirkarbeit Export"
name: "Werkstatt Gesamtblindleistung"
name: "Werkstatt Gesamtblindleistung Export"
update_interval: 29s
I would be grateful for any tips. All in all, it looks to me as if Grafana does not save any data that does not change. However, with other sensors (e.g. all current levels from the Shellys) this is saved and also displayed correctly.
Many thanks in advance.
