Hello fellas.
I have an issue with my data_template that i want to use for calling my robot vacuumer to start cleaning specific rooms based on some GUI layout in home assistant, everything is working fine except the last step with calling the automation correctly.
I fear that the data_template in automation seem to only return strings and can’t convert to a number array. I have tried all I can think off, hope anyone if more experienced. Thank you in advance!
Here’s my code:
- alias: Vacuum Selected Rooms
platform: state
entity_id: input_boolean.vacuum_startrooms
to: 'on'
- service: vacuum.send_command
data_template:
command: app_segment_clean
entity_id: vacuum.shiny
params: >-
{%- set rooms = {
"25": "input_boolean.vacuum_kitchen",
"17": "input_boolean.vacuum_bedroom",
"21": "input_boolean.vacuum_livingroom",
"19": "input_boolean.vacuum_hallway"
{%- for id in rooms %}
{%- if is_state(rooms[id], 'on') %}
{{ id }},
{%- endif %}
{%- endfor -%}
So i want the output to be something like: [17,19] e.g. in number format.
I’ve tried to use | int even after the {{ id }} and also around it all, doesnt seem to work.
The only thing that actually works is if i hardcode "params: [17,19] then it works…
I suspect as mention it is due to a string and somehow not converted correctly…
I get the following error no matter what: Unable to send command to the vacuum: {'code': -10000, 'message': 'data for segment is not a number'}
If the value 0 can be used to instruct your vacuum to ‘skip this room’ (i.e. ‘do nothing’) then you can use this template which has a fixed number of list items:
params:
- "{{ '25' if is_state('input_boolean.vacuum_kitchen', 'on') else '0'}}"
- "{{ '17' if is_state('input_boolean.vacuum_bedroom', 'on') else '0'}}"
- "{{ '21' if is_state('input_boolean.vacuum_livingroom', 'on') else '0'}}"
- "{{ '19' if is_state('input_boolean.vacuum_hallway', 'on') else '0'}}"
If 0 can’t be used that way then I don’t know how you can achieve your goal.
Thank you for all your replies.
I thought your suggestion @pnbruckner was worth a shot so I tried making my first python script(s).
However the comparison to “on” doesnt seem to work and i can’t figure out what is wrong, i’ve use the “logger” option to see some output of my script running.
I tried with the following code:
and the output from Home assistint in the docker view was:
2020-05-27 22:22:30 INFO (SyncWorker_10) [homeassistant.components.python_script.rooms_to_vacuum.py] params: [],
2020-05-27 22:22:30 INFO (SyncWorker_10) [homeassistant.components.python_script.rooms_to_vacuum.py] The State call: <state input_boolean.vacuum_hallway=on; editable=False, friendly_name=Hallway @ 2020-05-27T22:08:12.177876+02:00>,
2020-05-27 22:22:30 INFO (SyncWorker_10) [homeassistant.components.python_script.rooms_to_vacuum.py] Is state on?: False,
2020-05-27 22:22:30 INFO (SyncWorker_10) [homeassistant.components.python_script.rooms_to_vacuum.py] Room number: 19
Is it most likely my lack of python knowledge, but what’s wrong with that comparison?
If i toggle the hallway boolean it correcly states “off”, so i know that part works at least.
This forum needs a Design Patterns or Best Practices section where solutions to common challenges can be posted. For example, creating templates for rgb_color and params. Whereas rgb_color can be handled with a template (albeit not very elegantly), creating a dynamic list for params is beyond a template’s abilities. Your python_script is the best alternative I’ve seen and definitely a prime candidate for a Design Patterns section.
