Data Update Between MQTT, Sonoff & HA
I setup 2 sonoffs S31 with tasmota, one is hooked to TV to monitor power, the other hooked to receiver for the same, but also control powering on/off. I created an automation that says if tv gets above 5w, to turn on receiver, but seems to take a minute or two for that info to go thru the system and update in HA. Not sure if the power monitoring just updates slow in tasmota, if MQTT is slow, or… Any suggestions?
Edit: Think I figured it out after a lot of searching. Changed teleperiod in tasmota from 600 to 10. For this type of automation, seems to work good.
