Database on external NAS
Hello everyone,
I’m trying to get the database on an external NAS. After initially having problems with the connection, which I was able to solve, I now receive the following message`:
Logger: homeassistant.components.recorder
Source: components/recorder/util.py:86
Integration: Recorder (documentation, issues)
First occurred: 09:16:27 (1 occurrences)
Last logged: 09:16:27
Database error during schema migration
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1802, in _execute_context
    self.dialect.do_execute(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 719, in do_execute
    cursor.execute(statement, parameters)
  File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 206, in execute
    res = self._query(query)
  File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 319, in _query
    db.query(q)
  File "/usr/local/lib/python3.9/site-packages/MySQLdb/connections.py", line 259, in query
    _mysql.connection.query(self, query)
MySQLdb._exceptions.IntegrityError: (1364, "Field 'change_id' doesn't have a default value")
  File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 852, in _migrate_schema_and_setup_run
    migration.migrate_schema(self, current_version)
  File "/usr/src/homeassistant/homeassistant/components/recorder/migration.py", line 81, in migrate_schema
    _LOGGER.info("Upgrade to version %s done", new_version)
  File "/usr/local/lib/python3.9/contextlib.py", line 126, in __exit__
    next(self.gen)
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 86, in session_scope
    session.commit()
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 1428, in commit
    self._transaction.commit(_to_root=self.future)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 829, in commit
    self._prepare_impl()
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 808, in _prepare_impl
    self.session.flush()
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 3345, in flush
    self._flush(objects)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 3485, in _flush
    transaction.rollback(_capture_exception=True)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/langhelpers.py", line 70, in __exit__
    compat.raise_(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 207, in raise_
    raise exception
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 3445, in _flush
    flush_context.execute()
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/unitofwork.py", line 456, in execute
    rec.execute(self)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/unitofwork.py", line 630, in execute
    util.preloaded.orm_persistence.save_obj(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/persistence.py", line 244, in save_obj
    _emit_insert_statements(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/persistence.py", line 1221, in _emit_insert_statements
    result = connection._execute_20(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1614, in _execute_20
    return meth(self, args_10style, kwargs_10style, execution_options)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/elements.py", line 325, in _execute_on_connection
    return connection._execute_clauseelement(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1481, in _execute_clauseelement
    ret = self._execute_context(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1845, in _execute_context
    self._handle_dbapi_exception(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2026, in _handle_dbapi_exception
    util.raise_(
    raise exception
    db.query(q)
sqlalchemy.exc.IntegrityError: (MySQLdb._exceptions.IntegrityError) (1364, "Field 'change_id' doesn't have a default value")
[SQL: INSERT INTO schema_changes (schema_version, changed) VALUES (%s, %s)]
[parameters: (24, datetime.datetime(2022, 2, 4, 8, 16, 27, 534549, tzinfo=datetime.timezone.utc))]
(Background on this error at: https://sqlalche.me/e/14/gkpj)
Logger: aiohttp.server
Source: components/recorder/util.py:76
First occurred: 09:17:15 (1 occurrences)
Last logged: 09:17:15
Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 219, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/logbook/__init__.py", line 257, in get
    return await hass.async_add_executor_job(json_events)
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/src/homeassistant/homeassistant/components/logbook/__init__.py", line 245, in json_events
    _get_events(
  File "/usr/src/homeassistant/homeassistant/components/logbook/__init__.py", line 446, in _get_events
    with session_scope(hass=hass) as session:
  File "/usr/local/lib/python3.9/contextlib.py", line 119, in __enter__
    return next(self.gen)
  File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 76, in session_scope
    session = hass.data[DATA_INSTANCE].get_session()
TypeError: 'NoneType' object is not callable
Can someone help me please? Thank’s - Volker
Hello everyone,
I was able to solve the problem. Deleted the instance again and created an empty one. Now it comes (probably after the update, I love it when errors mix) Received invalid command: energy/info.
But the database errors are gone, the structure in the DB was created. Now I’ll wait 2 hours to see if data will appear in the energy dashboard again.
Best regards, Volker
