Okay, so I am one these people who suffer from recurrent database corruption problems. Those are possibly hardware related, according to what ppl say on forums (but the reason seems terribly difficult to trace).
Anyways, the repair routine for corrupted databases involves using the sqlite3 command line tool, you are supposed to run:
sqlite3 corrupted.db .recover > fixed.sql
Never worked in my case since many months, error message:
sql error: no such table: sqlite_dbpage (1)
I never understood what that might mean, not being familiar with SQL databases. I have now researched a bit, and one possibility seems to be that the db schema is not what the recover command expects.
The odd thing is that the error message comes up not only with the db that HA diagnosed to be corrupted, but ALSO when I run it on a copy of a freshly created db (autocreated by HA after the corrupt db was dumped and replaced automatically - I then shut down HA core, copied the NEW db to another computer, and ran the sqlite3 recover on the NEW db, getting the same error as on the corrupted dbs - which noone else of the ppl struggling with db corruption seemed to be getting).
So, what is wrong with my FRESH and non-corrupt db???
Below is the schema that I extracted - is there anything wrong with it?
The one thing that seems suspicious to me is :
CREATE TABLE sqlite_stat1(tbl,idx,stat);
because that shows up as an empty table. But that might be due to the table being freshly created.
Any insights?
Thanks a lot!
CREATE TABLE event_data (
data_id INTEGER NOT NULL,
hash BIGINT,
shared_data TEXT,
PRIMARY KEY (data_id)
CREATE TABLE event_types (
event_type_id INTEGER NOT NULL,
event_type VARCHAR(64),
PRIMARY KEY (event_type_id)
CREATE TABLE state_attributes (
attributes_id INTEGER NOT NULL,
hash BIGINT,
shared_attrs TEXT,
PRIMARY KEY (attributes_id)
CREATE TABLE states_meta (
metadata_id INTEGER NOT NULL,
entity_id VARCHAR(255),
PRIMARY KEY (metadata_id)
CREATE TABLE statistics_meta (
statistic_id VARCHAR(255),
source VARCHAR(32),
unit_of_measurement VARCHAR(255),
unit_class VARCHAR(255),
has_mean BOOLEAN,
has_sum BOOLEAN,
name VARCHAR(255),
mean_type SMALLINT NOT NULL,
PRIMARY KEY (id)
CREATE TABLE recorder_runs (
run_id INTEGER NOT NULL,
start DATETIME NOT NULL,
"end" DATETIME,
closed_incorrect BOOLEAN NOT NULL,
created DATETIME NOT NULL,
PRIMARY KEY (run_id)
CREATE TABLE migration_changes (
migration_id VARCHAR(255) NOT NULL,
version SMALLINT NOT NULL,
PRIMARY KEY (migration_id)
CREATE TABLE schema_changes (
change_id INTEGER NOT NULL,
schema_version INTEGER,
changed DATETIME NOT NULL,
PRIMARY KEY (change_id)
CREATE TABLE statistics_runs (
CREATE TABLE events (
event_id INTEGER NOT NULL,
event_type CHAR(0),
event_data CHAR(0),
origin CHAR(0),
origin_idx SMALLINT,
time_fired CHAR(0),
time_fired_ts FLOAT,
context_id CHAR(0),
context_user_id CHAR(0),
context_parent_id CHAR(0),
data_id INTEGER,
context_id_bin BLOB,
context_user_id_bin BLOB,
context_parent_id_bin BLOB,
event_type_id INTEGER,
PRIMARY KEY (event_id),
FOREIGN KEY(data_id) REFERENCES event_data (data_id),
FOREIGN KEY(event_type_id) REFERENCES event_types (event_type_id)
CREATE TABLE states (
state_id INTEGER NOT NULL,
entity_id CHAR(0),
state VARCHAR(255),
attributes CHAR(0),
event_id SMALLINT,
last_changed CHAR(0),
last_changed_ts FLOAT,
last_reported_ts FLOAT,
last_updated CHAR(0),
last_updated_ts FLOAT,
old_state_id INTEGER,
attributes_id INTEGER,
context_id CHAR(0),
metadata_id INTEGER,
PRIMARY KEY (state_id),
FOREIGN KEY(old_state_id) REFERENCES states (state_id),
FOREIGN KEY(attributes_id) REFERENCES state_attributes (attributes_id),
FOREIGN KEY(metadata_id) REFERENCES states_meta (metadata_id)
CREATE TABLE statistics (
created CHAR(0),
created_ts FLOAT,
start CHAR(0),
start_ts FLOAT,
mean FLOAT,
mean_weight FLOAT,
min FLOAT,
max FLOAT,
last_reset CHAR(0),
last_reset_ts FLOAT,
state FLOAT,
sum FLOAT,
PRIMARY KEY (id),
FOREIGN KEY(metadata_id) REFERENCES statistics_meta (id) ON DELETE CASCADE
CREATE TABLE statistics_short_term (
created CHAR(0),
created_ts FLOAT,
start CHAR(0),
start_ts FLOAT,
mean FLOAT,
mean_weight FLOAT,
min FLOAT,
max FLOAT,
last_reset CHAR(0),
state FLOAT,
sum FLOAT,
PRIMARY KEY (id),
CREATE INDEX ix_event_data_hash ON event_data (hash);
CREATE UNIQUE INDEX ix_event_types_event_type ON event_types (event_type);
CREATE INDEX ix_state_attributes_hash ON state_attributes (hash);
CREATE UNIQUE INDEX ix_states_meta_entity_id ON states_meta (entity_id);
CREATE UNIQUE INDEX ix_statistics_meta_statistic_id ON statistics_meta (statistic_id);
CREATE INDEX ix_recorder_runs_start_end ON recorder_runs (start, "end");
CREATE INDEX ix_statistics_runs_start ON statistics_runs (start);
CREATE INDEX ix_events_event_type_id_time_fired_ts ON events (event_type_id, time_fired_ts);
CREATE INDEX ix_events_context_id_bin ON events (context_id_bin);
CREATE INDEX ix_events_data_id ON events (data_id);
CREATE INDEX ix_events_time_fired_ts ON events (time_fired_ts);
CREATE INDEX ix_states_old_state_id ON states (old_state_id);
CREATE INDEX ix_states_context_id_bin ON states (context_id_bin);
CREATE INDEX ix_states_metadata_id_last_updated_ts ON states (metadata_id, last_updated_ts);
CREATE INDEX ix_states_last_updated_ts ON states (last_updated_ts);
CREATE INDEX ix_states_attributes_id ON states (attributes_id);
CREATE UNIQUE INDEX ix_statistics_statistic_id_start_ts ON statistics (metadata_id, start_ts);
CREATE INDEX ix_statistics_start_ts ON statistics (start_ts);
CREATE UNIQUE INDEX ix_statistics_short_term_statistic_id_start_ts ON statistics_short_term (metadata_id, start_ts);
CREATE INDEX ix_statistics_short_term_start_ts ON statistics_short_term (start_ts);
