Thanks for an idea
But this is not the case as DB is some GB but free space on SSD is over 80GB.
Downloaded the DB and repaired it with sqlite3 tools. Uploaded and now another problem arose:
Logija: homeassistant.components.recorder.core
Allikas: components/recorder/core.py:907
sidumine: Recorder (dokumentatsioon, probleemi)
Esmalt esines: 09:25:26 (1 esinemist)
Viimati logitud: 09:25:26
Unhandled database error while processing task PurgeTask(purge_before=datetime.datetime(2025, 4, 9, 6, 25, 22, 532233, tzinfo=datetime.timezone.utc), repack=False, apply_filter=False)
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1964, in _exec_single_context
self.dialect.do_execute(
cursor, str_statement, effective_parameters, context
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/default.py", line 942, in do_execute
cursor.execute(statement, parameters)
sqlite3.IntegrityError: FOREIGN KEY constraint failed
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 907, in _process_one_task_or_event_or_recover
task.run(self)
File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 120, in run
if purge.purge_old_data(
instance, self.purge_before, self.repack, self.apply_filter
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 642, in wrapper
return job(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/recorder/purge.py", line 121, in purge_old_data
_purge_old_entity_ids(instance, session)
File "/usr/src/homeassistant/homeassistant/components/recorder/purge.py", line 570, in _purge_old_entity_ids
deleted_rows = session.execute(delete_states_meta_rows(states_metadata_ids))
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/session.py", line 2365, in execute
return self._execute_internal(
statement,
...<4 lines>...
_add_event=_add_event,
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/session.py", line 2251, in _execute_internal
result: Result[Any] = compile_state_cls.orm_execute_statement(
self,
...<4 lines>...
conn,
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/bulk_persistence.py", line 2021, in orm_execute_statement
return super().orm_execute_statement(
session, statement, params, execution_options, bind_arguments, conn
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/orm/context.py", line 306, in orm_execute_statement
result = conn.execute(
statement, params or {}, execution_options=execution_options
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1416, in execute
return meth(
self,
distilled_parameters,
execution_options or NO_OPTIONS,
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/sql/lambdas.py", line 597, in _execute_on_connection
return connection._execute_clauseelement(
self, distilled_params, execution_options
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1638, in _execute_clauseelement
ret = self._execute_context(
dialect,
...<8 lines>...
cache_hit=cache_hit,
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1843, in _execute_context
return self._exec_single_context(
dialect, context, statement, parameters
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 1983, in _exec_single_context
self._handle_dbapi_exception(
e, str_statement, effective_parameters, cursor, context
File "/usr/local/lib/python3.13/site-packages/sqlalchemy/engine/base.py", line 2352, in _handle_dbapi_exception
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
sqlalchemy.exc.IntegrityError: (sqlite3.IntegrityError) FOREIGN KEY constraint failed
[SQL: DELETE FROM states_meta WHERE states_meta.metadata_id IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
[parameters: (43046, 42029, 43047, 2054, 2055, 2056, 2057, 2058, 2059, 2060, 2061, 2062, 2063, 2064, 2065, 2066, 2067, 2068, 2069, 2070, 2071, 2072, 2073, 2074, 27, 2075, 2076, 2077, 2078, 2079, 2080, 2081, 2082, 2083, 2084, 2085, 39, 2086, 2087, 2088, 2089, 2090, 2091, 2092, 2093, 2094, 2095, 2096, 2097, 2098 ... 34 parameters truncated ... 215, 43315, 43317, 43327, 43358, 2912, 43398, 43399, 396, 43405, 40847, 40848, 43415, 43416, 42394, 42395, 42396, 42397, 42404, 42407, 42011, 41897, 43433, 43434, 42012, 43439, 944, 43440, 42013, 43441, 43442, 1974, 42014, 42015, 42016, 35271, 42017, 42018, 42447, 42019, 42020, 42021, 42022, 42023, 42024, 33772, 42025, 42026, 42027, 42028)]
(Background on this error at: https://sqlalche.me/e/20/gkpj)
So I guess I backup the DB for further investigation and start with new one
Is it possible to merge/concat two databases into one after finding a solution?
Best (and clueless) JR
