Configured Hyper-V virtual machine according to Windows - Home Assistant
Additional disk artificially limited and not recognized by Home Assistant as hard drive. Homeassistant happily runs using the very same SCSI controller and provided .vhdx image. How is datadisk added to Hyper-V installations? Also Web UI doesn’t list /dev/sdb in datadisk dropdown:
## Move datadisk
No suitable attached devices found
[core-ssh ~]$ ha os datadisk move /dev/sdb
Error: '/dev/sdb' is not a harddisk!
Excerpt form hardware info:
[core-ssh ~]$ ha hardware info
devices:
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1
DEVNAME: /dev/sda
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda
DEVTYPE: disk
ID_BUS: scsi
ID_MODEL: Virtual_Disk
ID_MODEL_ENC: Virtual\x20Disk\x20\x20\x20\x20
ID_PART_TABLE_TYPE: gpt
ID_PART_TABLE_UUID: f567bb20-8bdc-46fa-adc9-a100348ce94b
ID_PATH: acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1
ID_PATH_TAG: acpi-VMBUS_00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_SERIAL: 360022480bcd9d4c82f3f7f5a0d711bd2
ID_SERIAL_SHORT: 60022480bcd9d4c82f3f7f5a0d711bd2
ID_TYPE: disk
ID_VENDOR: Msft
ID_VENDOR_ENC: Msft\x20\x20\x20\x20
ID_WWN: "0x60022480bcd9d4c8"
ID_WWN_VENDOR_EXTENSION: "0x2f3f7f5a0d711bd2"
ID_WWN_WITH_EXTENSION: 0x60022480bcd9d4c82f3f7f5a0d711bd2
MAJOR: "8"
MINOR: "0"
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "833369"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2
dev_path: /dev/sda
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part1 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part1
/dev/disk/by-label/hassos-boot /dev/disk/by-partlabel/hassos-boot /dev/disk/by-partuuid/b3dd0952-733c-4c88-8cba-cab9b8b4377f
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part1
/dev/disk/by-uuid/75DB-B1FC
DEVNAME: /dev/sda1
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda1
DEVTYPE: partition
ID_BUS: scsi
ID_FS_LABEL: hassos-boot
ID_FS_LABEL_ENC: hassos-boot
ID_FS_TYPE: vfat
ID_FS_USAGE: filesystem
ID_FS_UUID: 75DB-B1FC
ID_FS_UUID_ENC: 75DB-B1FC
ID_FS_VERSION: FAT16
ID_PART_ENTRY_DISK: "8:0"
ID_PART_ENTRY_NAME: hassos-boot
ID_PART_ENTRY_NUMBER: "1"
ID_PART_ENTRY_OFFSET: "2048"
ID_PART_ENTRY_SCHEME: gpt
ID_PART_ENTRY_SIZE: "65536"
ID_PART_ENTRY_TYPE: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
ID_PART_ENTRY_UUID: b3dd0952-733c-4c88-8cba-cab9b8b4377f
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "1"
PARTN: "1"
PARTNAME: hassos-boot
SUBSYSTEM: block
TAGS: ':systemd:'
UDISKS_IGNORE: "1"
USEC_INITIALIZED: "887171"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part1
dev_path: /dev/sda1
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda1
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part2 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part2
/dev/disk/by-label/hassos-kernel /dev/disk/by-partlabel/hassos-kernel0 /dev/disk/by-partuuid/26700fc6-b0bc-4ccf-9837-ea1a4cba3e65
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part2
/dev/disk/by-uuid/c51a9188-50de-480d-91e0-6d7c0e8c72cc
DEVNAME: /dev/sda2
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda2
DEVTYPE: partition
ID_BUS: scsi
ID_FS_LABEL: hassos-kernel
ID_FS_LABEL_ENC: hassos-kernel
ID_FS_TYPE: ext4
ID_FS_UUID: c51a9188-50de-480d-91e0-6d7c0e8c72cc
ID_FS_UUID_ENC: c51a9188-50de-480d-91e0-6d7c0e8c72cc
ID_FS_VERSION: "1.0"
ID_PART_ENTRY_NAME: hassos-kernel0
ID_PART_ENTRY_NUMBER: "2"
ID_PART_ENTRY_OFFSET: "67584"
ID_PART_ENTRY_SIZE: "49152"
ID_PART_ENTRY_TYPE: 0fc63daf-8483-4772-8e79-3d69d8477de4
ID_PART_ENTRY_UUID: 26700fc6-b0bc-4ccf-9837-ea1a4cba3e65
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "2"
PARTN: "2"
PARTNAME: hassos-kernel0
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "906745"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part2
dev_path: /dev/sda2
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda2
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part3 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part3
/dev/disk/by-partlabel/hassos-system0 /dev/disk/by-partuuid/8d3d53e3-6d49-4c38-8349-aff6859e82fd
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part3
DEVNAME: /dev/sda3
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda3
DEVTYPE: partition
ID_BUS: scsi
ID_FS_TYPE: squashfs
ID_FS_VERSION: "4.0"
ID_PART_ENTRY_NAME: hassos-system0
ID_PART_ENTRY_NUMBER: "3"
ID_PART_ENTRY_OFFSET: "116736"
ID_PART_ENTRY_SIZE: "524288"
ID_PART_ENTRY_UUID: 8d3d53e3-6d49-4c38-8349-aff6859e82fd
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "3"
PARTN: "3"
PARTNAME: hassos-system0
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "891939"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part3
dev_path: /dev/sda3
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda3
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part4 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part4
/dev/disk/by-partlabel/hassos-kernel1 /dev/disk/by-partuuid/fc02a4f0-5350-406f-93a2-56cbed636b5f
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part4
DEVNAME: /dev/sda4
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda4
DEVTYPE: partition
ID_BUS: scsi
ID_PART_ENTRY_NAME: hassos-kernel1
ID_PART_ENTRY_NUMBER: "4"
ID_PART_ENTRY_OFFSET: "641024"
ID_PART_ENTRY_UUID: fc02a4f0-5350-406f-93a2-56cbed636b5f
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "4"
PARTN: "4"
PARTNAME: hassos-kernel1
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "870074"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part4
dev_path: /dev/sda4
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda4
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part5 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part5
/dev/disk/by-partlabel/hassos-system1 /dev/disk/by-partuuid/a3ec664e-32ce-4665-95ea-7ae90ce9aa20
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part5
DEVNAME: /dev/sda5
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda5
DEVTYPE: partition
ID_BUS: scsi
ID_PART_ENTRY_NAME: hassos-system1
ID_PART_ENTRY_NUMBER: "5"
ID_PART_ENTRY_OFFSET: "690176"
ID_PART_ENTRY_UUID: a3ec664e-32ce-4665-95ea-7ae90ce9aa20
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "5"
PARTN: "5"
PARTNAME: hassos-system1
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "883176"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part5
dev_path: /dev/sda5
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda5
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part6 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part6
/dev/disk/by-partlabel/hassos-bootstate /dev/disk/by-partuuid/33236519-7f32-4dff-8002-3390b62c309d
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part6
DEVNAME: /dev/sda6
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda6
DEVTYPE: partition
ID_BUS: scsi
ID_PART_ENTRY_NAME: hassos-bootstate
ID_PART_ENTRY_NUMBER: "6"
ID_PART_ENTRY_OFFSET: "1214464"
ID_PART_ENTRY_SIZE: "16384"
ID_PART_ENTRY_UUID: 33236519-7f32-4dff-8002-3390b62c309d
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "6"
PARTN: "6"
PARTNAME: hassos-bootstate
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "893691"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part6
dev_path: /dev/sda6
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda6
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part7 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part7
/dev/disk/by-label/hassos-overlay /dev/disk/by-partlabel/hassos-overlay /dev/disk/by-partuuid/f1326040-5236-40eb-b683-aaa100a9afcf
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part7
/dev/disk/by-uuid/9914b26a-cf8f-483e-b3cb-7eb965b456c5
DEVNAME: /dev/sda7
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda7
DEVTYPE: partition
ID_BUS: scsi
ID_FS_LABEL: hassos-overlay
ID_FS_LABEL_ENC: hassos-overlay
ID_FS_TYPE: ext4
ID_FS_UUID: 9914b26a-cf8f-483e-b3cb-7eb965b456c5
ID_FS_UUID_ENC: 9914b26a-cf8f-483e-b3cb-7eb965b456c5
ID_PART_ENTRY_NAME: hassos-overlay
ID_PART_ENTRY_NUMBER: "7"
ID_PART_ENTRY_OFFSET: "1230848"
ID_PART_ENTRY_SIZE: "196608"
ID_PART_ENTRY_UUID: f1326040-5236-40eb-b683-aaa100a9afcf
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "7"
PARTN: "7"
PARTNAME: hassos-overlay
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "894337"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part7
dev_path: /dev/sda7
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda7
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part8 /dev/disk/by-id/wwn-0x60022480bcd9d4c82f3f7f5a0d711bd2-part8
/dev/disk/by-label/hassos-data /dev/disk/by-partlabel/hassos-data /dev/disk/by-partuuid/a52a4597-fa3a-4851-aefd-2fbe9f849079
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-1-part8
/dev/disk/by-uuid/4c20810d-9c08-4ef4-b315-54b699f03001
DEVNAME: /dev/sda8
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda8
DEVTYPE: partition
ID_BUS: scsi
ID_FS_LABEL: hassos-data
ID_FS_LABEL_ENC: hassos-data
ID_FS_TYPE: ext4
ID_FS_UUID: 4c20810d-9c08-4ef4-b315-54b699f03001
ID_FS_UUID_ENC: 4c20810d-9c08-4ef4-b315-54b699f03001
ID_PART_ENTRY_NAME: hassos-data
ID_PART_ENTRY_NUMBER: "8"
ID_PART_ENTRY_OFFSET: "1427456"
ID_PART_ENTRY_SIZE: "65681375"
ID_PART_ENTRY_UUID: a52a4597-fa3a-4851-aefd-2fbe9f849079
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_TYPE: disk
ID_VENDOR: Msft
MAJOR: "8"
MINOR: "8"
PARTN: "8"
PARTNAME: hassos-data
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "908128"
by_id: /dev/disk/by-id/scsi-360022480bcd9d4c82f3f7f5a0d711bd2-part8
dev_path: /dev/sda8
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/block/sda/sda8
- attributes:
DEVNAME: /dev/bsg/0:0:0:1
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/bsg/0:0:0:1
MAJOR: "248"
MINOR: "0"
SUBSYSTEM: bsg
by_id: null
dev_path: /dev/bsg/0:0:0:1
subsystem: bsg
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/bsg/0:0:0:1
- attributes:
DEVNAME: /dev/sg0
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/scsi_generic/sg0
MAJOR: "21"
MINOR: "0"
SUBSYSTEM: scsi_generic
by_id: null
dev_path: /dev/sg0
subsystem: scsi_generic
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:1/scsi_generic/sg0
- attributes:
DEVLINKS: /dev/disk/by-id/scsi-360022480d065c4112ee60208641a4b75 /dev/disk/by-id/wwn-0x60022480d065c4112ee60208641a4b75
/dev/disk/by-path/acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-2
DEVNAME: /dev/sdb
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:2/block/sdb
DEVTYPE: disk
ID_BUS: scsi
ID_PATH: acpi-VMBUS:00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-2
ID_PATH_TAG: acpi-VMBUS_00-vmbus-31ffd26b89e445ab98f44fbcddcfa398-lun-2
ID_REVISION: "1.0"
ID_SCSI: "1"
ID_SERIAL: 360022480d065c4112ee60208641a4b75
ID_SERIAL_SHORT: 60022480d065c4112ee60208641a4b75
ID_TYPE: disk
ID_VENDOR: Msft
ID_WWN: "0x60022480d065c411"
ID_WWN_VENDOR_EXTENSION: "0x2ee60208641a4b75"
ID_WWN_WITH_EXTENSION: 0x60022480d065c4112ee60208641a4b75
MAJOR: "8"
MINOR: "16"
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: "934976"
by_id: /dev/disk/by-id/scsi-360022480d065c4112ee60208641a4b75
dev_path: /dev/sdb
subsystem: block
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:2/block/sdb
- attributes:
DEVNAME: /dev/bsg/0:0:0:2
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:2/bsg/0:0:0:2
MAJOR: "248"
MINOR: "1"
SUBSYSTEM: bsg
by_id: null
dev_path: /dev/bsg/0:0:0:2
subsystem: bsg
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:2/bsg/0:0:0:2
- attributes:
DEVNAME: /dev/sg1
DEVPATH: /devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:2/scsi_generic/sg1
MAJOR: "21"
MINOR: "1"
by_id: null
dev_path: /dev/sg1
sysfs: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/ACPI0004:00/VMBUS:00/31ffd26b-89e4-45ab-98f4-4fbcddcfa398/host0/target0:0:0/0:0:0:2/scsi_generic/sg1
