I’ve been told that this is going to be hard to do in HA, but i’ll try yo reach out in here anyway.
I’m controlling a bunch of aquariums from HA, and i would like to create a dropdown where i can select: Waterchange, Firtilizer, Quarantine + the possibility to add more.
When a subject is chosen, all that happens is that the text of the subject + todays date to another card:
This is a single card? Both containing the dropdown and the result-text with datestamp?
Maybe i should have told, that my experience in Home Assistant still is rather defective. I’m thrilled that there’s an easy solution, but i would really appreciate it if you could be a bit more specific on how to implement the solution. Thank you SO much.
That is an automation.
It could be done in a card too, but I find it easier if automations are in automations.
So create the two helpers, the select with the actions and the text.
When you select something then it triggers.
Ok. I succeeded in creating the automation (i think), but i can’t figure out how to transfer the data from the select and automation, and in to another card.
By the way - did i mention that my intention is to have a log with dates for various maintenance tasks in the aquarium? So this automation will, in time, show a list of dates and the type of maintenance done on that day.
No, that kind of storage is not suitable in Home Assistant.
I would recommend google sheets integration in that case.
So you can have the input text with the last time, and in sheets you have them all.
Thank you so much @Hellis81
The Google Sheet integration did the job, combined with the yaml you posted earlier. I am very greatful for your help.
Now i’ve been googlin’ how to get the data back into a card on the dashboard. There’s a lot of guides out there on how to append data to Google Sheet, but strangely i can’t seem to find any on how to get it back.
Yes. I meant from Sheets to HA.
Today we are writing the update on the glass of the aquarium with a sharpie
We have a tablet with a dashboard on each tank with temperature measurement and what not, and I just figured it would be a lot easier to push a button to make a date stamp.
The list could potentially get long yes, but it’s mostly a matter of remembering last time it was done and show it on the screen.
