Hello Everybody
I recently upgraded my Raspberry Pi 3 B+ to “Debian GNU/Linux 12 (bookworm)” and reinstalled "Home Assistant Core 2025.4.2 (on Docker) ". Now I’m encountering an error that I didn’t have before on the same hardware and that I haven’t been able to resolve yet. Perhaps someone here has already seen it and can give me some suggestions.
Bluetooth isn’t working, and I’m seeing this error:
Failed setup, will retry: hci0 (B8:27:xx:xx:xx:xx): hci0 (B8:27:xx:xx:xx:xx):
DBus service not found; docker config may be missing -v /run/dbus:/run/dbus:ro: {ex}
My Docker configuration is as follows:
services:
home-assistant:
container_name: home-assistant
image: ghcr.io/home-assistant/home-assistant:stable
volumes:
- "~/homeassistant/.homeassistant:/config"
- "/run/dbus:/run/dbus:ro"
environment:
- TZ=Europe/Rome
network_mode: host
restart: always
privileged: true
The Raspberry Pi’s internal Bluetooth antenna is working correctly.
$ hcitool dev
Devices:
hci0 B8:27:xx:xx:xx:xx
From what I understand, the problem seems to be with the Docker configuration not correctly recognizing the Bluetooth device. If anyone has any suggestions, I thank you in advance ![]()
All the best
Mauro
