DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
Anyone know how to change those timestamps to 12hr vs 24hr.
Currently it’s not possible but i’m working on it. Things like 12hr vs 24hr and Celsius vs Fahrenheit
I have the same in the android app. Does his apply there also?
Yes, i’m waiting on the update of it.
Again a reminder for users of my theme to not upgrade to HA 0.107 it will break my theme and Custom Header is not (yet) ready for HA 0.107 I need to wait for him to first fix the Custom Header plugin untill I can bring out a release for HA 0.107
after following the installation guide using the latest version I get the following errors - any idea what the issue is?
Unable to set up dependencies of dwains_theme. Setup failed for dependencies: lovelace
2020-03-27 17:43:27 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: lovelace
2020-03-27 17:43:27 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2020-03-27 17:43:28 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of hacs. Setup failed for dependencies: frontend, lovelace
2020-03-27 17:43:28 ERROR (MainThread) [homeassistant.setup] Setup failed for hacs: Could not set up all dependencies.
2020-03-27 17:43:28 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2020-03-27 17:43:28 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2020-03-27 17:43:28 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2020-03-27 17:43:28 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2020-03-27 17:43:29 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, logbook, map
2020-03-27 17:43:29 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2020-03-27 17:43:32 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
I’m having the same problem. I assume this is due to the incompatibility with Custom Headers and v0.107?
Correct. 1.3.0 (soon to be beta released) from dwains theme and CH, which is currently beta testing, will be fully compatible with 107.
tried to in stall theme, however i get an error in notifications
Invalid config
The following integrations and platforms could not be set up:
  • dwains_theme
Please check your config.
5 minutes ago
Log Details (ERROR)
Logger: homeassistant.setup
Source: custom_components/dwains_theme/init.py:290
First occurred: 7:47:48 PM (1 occurrences)
Last logged: 7:47:48 PM
Error during setup of component dwains_theme
File “/usr/src/homeassistant/homeassistant/setup.py”, line 170, in _async_setup_component
hass, processed_config
File “/config/custom_components/dwains_theme/init.py”, line 290, in async_setup
dwains_theme_config.update(config.get(“dwains_theme”)[“configuration”]);
KeyError: ‘configuration’
Did you followed the installation guide step by step?
Any ETA on v1.3.0? No complaint…just curious. Thanks.
I’m working on a pre-beta now with some people in my discord channel. Planning on releasing a beta this week and an official release next week.
hey there looks like amazing work, i followed instructions but i am getting only safe mode…
how to define the folder here ?
i assume it should be packages ?
are you running HA 0.106?
no…
0.107…
now i see no support…
Only pre-beta 1.3 works on 0.107.
I’m working hard on v1.3.0 which will be 0.107 compatible :smiley:
I almost re-coded the whole theme and added a lot of new FEATURES.
I must say that v1.3.0 will be sort of a beta. It will have some small bugs and some unfinished things but it still very usable. I will release v1.3.0 asap so I can work hard on fixing all things in a v1.3.1 version. But then with v1.3.0 you can all upgrade to HA 0.107.
Sneak peek on v1.3.0 :smiley:
