DD - Automatic area-based dashboard for desktop, tablet and mobile - V3.7.0
Good job @dwains was a delight to see you debug the speed issue. Upgraded to 1.3.1 as well, thanks!
Very nice screens and inspirational work. I have yet to use this package but your temperature screen looks just like something I need.
Is anyone having an issue on mobile with custom header not applying? The menu is supposed to be on the bottom. Some rare times it does show up on the bottom.
Three dots upper right corner and reload resources followed by a refresh fixed for me. Might need to clear browser cache as well.
100% fixed. It was the three dots and refresh Lovelace. Then I refreshed the whole page and it worked. No cache as I had already done that.
Okay so it works now? Sometimes the header doesn’t load then you need to do a refresh then it works. It’s a bug in CH which still needs to be fixed by @mayker
Thanks @Dwains for 1.3.1. The Speed for such a mighty theme is insane
I still have yet to have anyone post an issue related to this on the CH github page with the required info. On the only iOS devices I own (old iPhone and older iPad) everything is working as it should as far as I know. Is this issue strictly happening on iOS devices, just the iOS app, in all browsers on an iOS device, etc? Without any info it’s impossible for me to troubleshoot or track this down.
Works for me now!
I was using Galaxy s10+ all up to date on Chrome
Yes I run 1.3.1.
I would like to have the side bar on the left to disappear.
Please upgrade to HA 0.108 then click bottom left on your profile (blue circle with letter of your name in it) then there select default dashboard to be Dwains Theme, you can also there hide the sidemenu with a toggle.
Thx that was it, I could also hide the side bar from HA 0.107
is this support 0.107?
I am getting Package dwains_theme_configuration setup failed. Component lovelace has duplicate key ‘mode’
Yes, it works. The theme is sooo fast now!
Hey i did the installation but plugins not working, it says it cannot find resource …
should i remove resources from my YAML file?
Custom element doesn’t exist: mod-card.
Yes and also HA 0.108
Make sure you installed all required HACS plugins.
Is there a way to integrate all entities automatically?
