I have the same problem.
I installed the beta version of iPadOS 15 on my tablet and since then the tab bar is at the bottom of the page. An update coming soon?
having the same problem
Did you manage to solve it ?
How did you make the calendar Add-on to work? My calendar add-on doesn’t pop up in the house information?
Thanks in Advance
Is there a way to have the dashboard consider a vacuum that is charging as being “off”? I have two vacuums - one which shows as off when docked, the 2nd vacuums state shows as docked - even if it’s docked for says - which means one vacuum as shows as “not off”.
Any sugestions?
Have mine working from following instructions here.
It doesn’t popup - it just displays on the house information page - don’t think it’s meant to popup
Im sure i am just having a stupid moment, but i have finally gotten around to installing this, and having an issue. I have followed the installation guide, and have the integration installed.
But, i have no configs directory. This is what I see this in the UI
Try to clear your browser cache
I forgot to update this thread — it fixed itself after the next HA reboot, all of a sudden the folders were there.
Hi, is there any Way to list custom addons, like the vacuum addon, unter the “devices” view in the Dashboard ? Also i have a custom addon for my fan which is controlled by a broadlink device (service calls, or script calls) . It would be awesome if devices which exists only as addon, get’s listet in the devices view on Dashboard also.
Anyone got the theme working on 2021.7.4?
I’ve recently updated from 2021.2 and now I get “unknown error” when trying to access the dashboard.
I’m on the latest version of Dwain’s dashboard.
How did you get your name after “Guten Abend”?
Is there a way to work with variables to show the current logged in user name?
updated like 10 minutes ago and have no problem to access the dashboard.
everything works. look into the logs if you get an error.
I have a problem with the light card not showing up correctly. When I toggle the light, the light buttons work ok. But when I long press to change brightness or color is shows this card:
What do I need to do to make it work correctly?
Hey,
I’ve installed Dwains Dashboard and everything is working fine so far.
Only one thing concerns me: How to get the Icons in the bottom bar (header) centered like in the screenshot?
Please help!
Hej, I’m trying to get this working bu I’m stuck at the image as it doesn’t display.
I followed all steps but I’m stuck somewhere
What happens when you try to clean it with the service call “dwains_dashboard.notification_dismiss” ? Maybe it’s just a UI issue
didnt now about that
thx
Anyone else finding that clicking on the person icon cause the browser to lock up, specifically on IOS.
Dev console gives thousands of these errors
button-card.js:425 hui-error-card TypeError: n.setConfig is not a function
at n (:8123/dwains_dashboard/cards/button-card/button-card.js:425)
at i (:8123/dwains_dashboard/cards/button-card/button-card.js:425)
