DD-WRT Connection Pool Error Occasionally
Every now and then after restart of HASS, connection to the DDWRT cant be established and I have to restarte few times and it will reconnect eventually. Is this a bug? or is there anyway to fix this?
Router details:
Firmware: DD-WRT v24-sp2 (04/16/14) kongac
Netgear R7000
 16-07-31 20:21:51 homeassistant.components.device_tracker.ddwrt: Connection to the router timed out
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 385, in _make_request
    httplib_response = conn.getresponse(buffering=True)
TypeError: getresponse() got an unexpected keyword argument 'buffering'
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 387, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.4/http/client.py", line 1172, in getresponse
    response.begin()
  File "/usr/lib/python3.4/http/client.py", line 351, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.4/http/client.py", line 313, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/lib/python3.4/socket.py", line 371, in readinto
    return self._sock.recv_into(b)
socket.timeout: timed out
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 403, in send
    timeout=timeout
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 623, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 255, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/packages/six.py", line 310, in reraise
    raise value
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 578, in urlopen
    chunked=chunked)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 389, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 314, in _raise_timeout
    raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
requests.packages.urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='10.0.0.1', port=80): Read timed out. (read timeout=4)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/ddwrt.py", line 144, in get_ddwrt_data
    timeout=4)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/api.py", line 71, in get
    return request('get', url, params=params, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/api.py", line 57, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 475, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/sessions.py", line 585, in send
    r = adapter.send(request, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 479, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='10.0.0.1', port=80): Read timed out. (read timeout=4)
16-07-31 20:21:51 homeassistant.components.device_tracker: Error setting up platform ddwrt
I’m getting the same thing. Just swapped over to DD-WRT firmware last night. Latest Kong was a disaster. Couldn’t connect to anything through HASS. Errors everywhere. Downgraded to v24-sp2 and all was fine. Wondering if it is a security feature in firmware.
Anyone have an opinion on best, latest firmware for DD-WRT?
Not sure about your router but I believe I read that the Netgear routers have a limit on logins. If you are making a lot of changes and restarting HA a lot it may pull to many requests and the router could be blocking the requests. I have seen it with my router (a netgear) and its generally when I am making tweaks and restarting HA a bunch in one night.
