Hi Benoit,
Thanks for looking into it. Few minutes logs contains milion of records!
I tired to take out the most important part. Hope this helps you in the analysis.
If you have any idea how to debug the MODBUS please let me know. I can provide additional information.
2024-10-12 08:25:47,215 - __main__ - CRITICAL - Modbus interface address: 192.168.1.153 : 20108
2024-10-12 08:25:47,216 - __main__ - CRITICAL - Modbus regulator address: 0xa
2024-10-12 08:25:47,216 - __main__ - CRITICAL - Broker: 192.168.1.199 : 1883
2024-10-12 08:25:47,217 - __main__ - CRITICAL - Topic Root: home/heater/boiler
2024-10-12 08:25:47,217 - __main__ - CRITICAL - Hassio Discovery Enable: True
2024-10-12 08:25:47,217 - __main__ - CRITICAL - Hassio Discovery Prefix: homeassistant
2024-10-12 08:25:47,217 - __main__ - CRITICAL - Regulator type is Diematic3
2024-10-12 08:25:47,280 - Diematic - INFO - Using tzinfo ('CET') for Boiler time sync
2024-10-12 08:25:47,282 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:25:47,383 - __main__ - DEBUG - Paho MQTT version 2.XX or more detected, using callback API version1
2024-10-12 08:25:47,398 - __main__ - CRITICAL - Connected to MQTT broker
2024-10-12 08:25:47,399 - __main__ - INFO - Publish :home/heater/boiler/status Offline
2024-10-12 08:25:47,447 - __main__ - INFO - Sending HA discovery messages
2024-10-12 08:26:27,445 - Diematic - WARNING - Synchro timeout
2024-10-12 08:26:27,447 - __main__ - INFO - Publish :home/heater/boiler/date
2024-10-12 08:26:27,448 - __main__ - INFO - Publish :home/heater/boiler/lastTimeSync
2024-10-12 08:26:27,449 - __main__ - INFO - Publish :home/heater/boiler/type
2024-10-12 08:26:27,450 - __main__ - INFO - Publish :home/heater/boiler/ctrl
2024-10-12 08:26:27,452 - __main__ - INFO - Publish :home/heater/boiler/ext/temp
2024-10-12 08:26:27,455 - __main__ - INFO - Publish :home/heater/boiler/temp
2024-10-12 08:26:27,456 - __main__ - INFO - Publish :home/heater/boiler/targetTemp
2024-10-12 08:26:27,458 - __main__ - INFO - Publish :home/heater/boiler/returnTemp
2024-10-12 08:26:27,460 - __main__ - INFO - Publish :home/heater/boiler/waterPressure
2024-10-12 08:26:27,462 - __main__ - INFO - Publish :home/heater/boiler/power
2024-10-12 08:26:27,464 - __main__ - INFO - Publish :home/heater/boiler/smokeTemp
2024-10-12 08:26:27,466 - __main__ - INFO - Publish :home/heater/boiler/ionizationCurrent
2024-10-12 08:26:27,468 - __main__ - INFO - Publish :home/heater/boiler/fanSpeed
2024-10-12 08:26:27,470 - __main__ - INFO - Publish :home/heater/boiler/burnerStatus
2024-10-12 08:26:27,471 - __main__ - INFO - Publish :home/heater/boiler/pumpPower
2024-10-12 08:26:27,473 - __main__ - INFO - Publish :home/heater/boiler/alarm
2024-10-12 08:26:27,475 - __main__ - INFO - Publish :home/heater/boiler/hotWater/pump
2024-10-12 08:26:27,477 - __main__ - INFO - Publish :home/heater/boiler/hotWater/temp
2024-10-12 08:26:27,480 - __main__ - INFO - Publish :home/heater/boiler/hotWater/mode
2024-10-12 08:26:27,481 - __main__ - INFO - Publish :home/heater/boiler/hotWater/dayTemp
2024-10-12 08:26:27,482 - __main__ - INFO - Publish :home/heater/boiler/hotWater/nightTemp
2024-10-12 08:26:27,484 - __main__ - INFO - Publish :home/heater/boiler/zoneA/temp
2024-10-12 08:26:27,484 - __main__ - INFO - Publish :home/heater/boiler/zoneA/mode
2024-10-12 08:26:27,485 - __main__ - INFO - Publish :home/heater/boiler/zoneA/pump
2024-10-12 08:26:27,487 - __main__ - INFO - Publish :home/heater/boiler/zoneA/dayTemp
2024-10-12 08:26:27,489 - __main__ - INFO - Publish :home/heater/boiler/zoneA/nightTemp
2024-10-12 08:26:27,490 - __main__ - INFO - Publish :home/heater/boiler/zoneA/antiiceTemp
2024-10-12 08:26:27,491 - __main__ - INFO - Publish :home/heater/boiler/zoneB/temp
2024-10-12 08:26:27,492 - __main__ - INFO - Publish :home/heater/boiler/zoneB/mode
2024-10-12 08:26:27,494 - __main__ - INFO - Publish :home/heater/boiler/zoneB/pump
2024-10-12 08:26:27,496 - __main__ - INFO - Publish :home/heater/boiler/zoneB/dayTemp
2024-10-12 08:26:27,497 - __main__ - INFO - Publish :home/heater/boiler/zoneB/nightTemp
2024-10-12 08:26:27,498 - __main__ - INFO - Publish :home/heater/boiler/zoneB/antiiceTemp
2024-10-12 08:26:27,507 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:26:27,508 - DDModbus - DEBUG - Frame received:
2024-10-12 08:26:27,509 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:26:27,509 - Diematic - DEBUG - Bus status switched to SLAVE
2024-10-12 08:26:27,510 - DDModbus - DEBUG - Frame received:
2024-10-12 08:26:27,511 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:26:27,511 - DDModbus - DEBUG - Frame received:
2024-10-12 08:26:27,512 - DDModbus - DEBUG - Frame received:
2024-10-12 08:26:27,512 - DDModbus - WARNING - Received Frame Length Error
....this continue until....
2024-10-12 08:27:07,508 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:27:07,508 - DDModbus - DEBUG - Frame received:
2024-10-12 08:27:07,508 - Diematic - WARNING - Synchro timeout
2024-10-12 08:27:07,510 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:27:08,111 - Diematic - DEBUG - Bus status switched to MASTER after 40.60195469856262
2024-10-12 08:27:08,112 - Diematic - INFO - ModBus Master Slave Synchro OK
2024-10-12 08:27:08,112 - DDModbus - DEBUG - Send read request: 0a030001003f556100
2024-10-12 08:27:08,304 - DDModbus - DEBUG - Answer received: 0a037e000000000030000a001a0006005300be8046000100030000000000af00aa003c0008ffff0003000f0000000000d200b9003c000800ef00070016006401c20000ffff000000c800b4003c000800e200070016006401c20000ffff0000000000000000000000000000000000000000000000000000022600000002021d00008bed000000
2024-10-12 08:27:08,305 - DDModbus - DEBUG - Answer valid
2024-10-12 08:27:08,305 - DDModbus - DEBUG - Send read request: 0a0300400040449500
2024-10-12 08:27:08,525 - DDModbus - DEBUG - Answer received: 0a03800001000000000000000000000000000000000000006402528ccc2807091100000000000000000000000000000000000000000001000000000000000000000000006400000000000000000000004800000000000000000000000c000a0018000000008ccc000000000000025200000000000203200000000000000000000f03e0fd0c000000
2024-10-12 08:27:08,526 - DDModbus - DEBUG - Answer valid
2024-10-12 08:27:08,526 - DDModbus - DEBUG - Send read request: 0a0301800040455500
2024-10-12 08:27:08,738 - DDModbus - DEBUG - Answer received: 0a038000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000280001000000000000000000000000000000000064000e007800060002000000000000000009112807000038e9000000
2024-10-12 08:27:08,739 - DDModbus - DEBUG - Answer valid
2024-10-12 08:27:08,739 - DDModbus - DEBUG - Send read request: 0a0301c00017057f00
2024-10-12 08:27:08,848 - DDModbus - DEBUG - Answer received: 0a032e0000000000000000025202398ccc0000000e00180000021d00000000006400000000ffff0000800180010000800139a7000000
2024-10-12 08:27:08,849 - DDModbus - DEBUG - Answer valid
2024-10-12 08:27:08,850 - __main__ - INFO - Publish :home/heater/boiler/status Online
2024-10-12 08:27:08,850 - __main__ - INFO - Publish :home/heater/boiler/date 2024-10-12T10:26:00+02:00
2024-10-12 08:27:08,851 - __main__ - INFO - Publish :home/heater/boiler/type 24
2024-10-12 08:27:08,851 - __main__ - INFO - Publish :home/heater/boiler/ctrl 48
2024-10-12 08:27:08,852 - __main__ - INFO - Publish :home/heater/boiler/ext/temp 8.3
2024-10-12 08:27:08,852 - __main__ - INFO - Publish :home/heater/boiler/temp 59.4
2024-10-12 08:27:08,852 - __main__ - INFO - Publish :home/heater/boiler/targetTemp 0.0
2024-10-12 08:27:08,853 - __main__ - INFO - Publish :home/heater/boiler/returnTemp 56.9
2024-10-12 08:27:08,853 - __main__ - INFO - Publish :home/heater/boiler/waterPressure 1.4
2024-10-12 08:27:08,854 - __main__ - INFO - Publish :home/heater/boiler/power 0
2024-10-12 08:27:08,855 - __main__ - INFO - Publish :home/heater/boiler/smokeTemp -327.6
2024-10-12 08:27:08,855 - __main__ - INFO - Publish :home/heater/boiler/ionizationCurrent 0.0
2024-10-12 08:27:08,856 - __main__ - INFO - Publish :home/heater/boiler/fanSpeed 0
2024-10-12 08:27:08,856 - __main__ - INFO - Publish :home/heater/boiler/burnerStatus 0
2024-10-12 08:27:08,857 - __main__ - INFO - Publish :home/heater/boiler/alarm {"id": 65535, "txt": "D\u00e9faut inconnu"}
2024-10-12 08:27:08,857 - __main__ - INFO - Publish :home/heater/boiler/hotWater/pump 0
2024-10-12 08:27:08,857 - __main__ - INFO - Publish :home/heater/boiler/hotWater/temp 54.1
2024-10-12 08:27:08,858 - __main__ - INFO - Publish :home/heater/boiler/hotWater/mode AUTO
2024-10-12 08:27:08,859 - __main__ - INFO - Publish :home/heater/boiler/hotWater/dayTemp 55.0
2024-10-12 08:27:08,859 - __main__ - INFO - Publish :home/heater/boiler/hotWater/nightTemp 10.0
2024-10-12 08:27:08,859 - __main__ - INFO - Publish :home/heater/boiler/zoneB/temp 23.9
2024-10-12 08:27:08,860 - __main__ - INFO - Publish :home/heater/boiler/zoneB/mode AUTO
2024-10-12 08:27:08,860 - __main__ - INFO - Publish :home/heater/boiler/zoneB/pump 0
2024-10-12 08:27:08,860 - __main__ - INFO - Publish :home/heater/boiler/zoneB/dayTemp 21.0
2024-10-12 08:27:08,860 - __main__ - INFO - Publish :home/heater/boiler/zoneB/nightTemp 18.5
2024-10-12 08:27:08,860 - __main__ - INFO - Publish :home/heater/boiler/zoneB/antiiceTemp 6.0
2024-10-12 08:27:08,861 - Diematic - DEBUG - Now :2024-10-12 08:27:08.860927+00:00
2024-10-12 08:27:08,861 - Diematic - DEBUG - Boiler :2024-10-12 10:26:00+02:00
2024-10-12 08:27:08,861 - Diematic - DEBUG - Drift :68.860927
2024-10-12 08:27:08,861 - Diematic - DEBUG - Drift Counter:1
2024-10-12 08:27:48,916 - Diematic - WARNING - Synchro timeout
2024-10-12 08:27:48,917 - __main__ - INFO - Publish :home/heater/boiler/status Offline
2024-10-12 08:27:48,918 - __main__ - INFO - Publish :home/heater/boiler/date
2024-10-12 08:27:48,919 - __main__ - INFO - Publish :home/heater/boiler/type
2024-10-12 08:27:48,920 - __main__ - INFO - Publish :home/heater/boiler/ctrl
2024-10-12 08:27:48,921 - __main__ - INFO - Publish :home/heater/boiler/ext/temp
2024-10-12 08:27:48,923 - __main__ - INFO - Publish :home/heater/boiler/temp
2024-10-12 08:27:48,924 - __main__ - INFO - Publish :home/heater/boiler/targetTemp
2024-10-12 08:27:48,926 - __main__ - INFO - Publish :home/heater/boiler/returnTemp
2024-10-12 08:27:48,927 - __main__ - INFO - Publish :home/heater/boiler/waterPressure
2024-10-12 08:27:48,929 - __main__ - INFO - Publish :home/heater/boiler/power
2024-10-12 08:27:48,931 - __main__ - INFO - Publish :home/heater/boiler/smokeTemp
2024-10-12 08:27:48,932 - __main__ - INFO - Publish :home/heater/boiler/ionizationCurrent
2024-10-12 08:27:48,934 - __main__ - INFO - Publish :home/heater/boiler/fanSpeed
2024-10-12 08:27:48,936 - __main__ - INFO - Publish :home/heater/boiler/burnerStatus
2024-10-12 08:27:48,938 - __main__ - INFO - Publish :home/heater/boiler/alarm
2024-10-12 08:27:48,939 - __main__ - INFO - Publish :home/heater/boiler/hotWater/pump
2024-10-12 08:27:48,941 - __main__ - INFO - Publish :home/heater/boiler/hotWater/temp
2024-10-12 08:27:48,943 - __main__ - INFO - Publish :home/heater/boiler/hotWater/mode
2024-10-12 08:27:48,944 - __main__ - INFO - Publish :home/heater/boiler/hotWater/dayTemp
2024-10-12 08:27:48,946 - __main__ - INFO - Publish :home/heater/boiler/hotWater/nightTemp
2024-10-12 08:27:48,948 - __main__ - INFO - Publish :home/heater/boiler/zoneB/temp
2024-10-12 08:27:48,950 - __main__ - INFO - Publish :home/heater/boiler/zoneB/mode
2024-10-12 08:27:48,952 - __main__ - INFO - Publish :home/heater/boiler/zoneB/pump
2024-10-12 08:27:48,953 - __main__ - INFO - Publish :home/heater/boiler/zoneB/dayTemp
2024-10-12 08:27:48,955 - __main__ - INFO - Publish :home/heater/boiler/zoneB/nightTemp
2024-10-12 08:27:48,956 - __main__ - INFO - Publish :home/heater/boiler/zoneB/antiiceTemp
2024-10-12 08:27:48,964 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:27:48,964 - DDModbus - DEBUG - Frame received:
2024-10-12 08:27:48,965 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:27:48,966 - Diematic - DEBUG - Bus status switched to SLAVE
2024-10-12 08:27:48,966 - DDModbus - DEBUG - Frame received:
2024-10-12 08:27:48,967 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:27:48,967 - DDModbus - DEBUG - Frame received:
2024-10-12 08:27:48,968 - DDModbus - DEBUG - Frame received:
2024-10-12 08:27:48,968 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:27:48,969 - DDModbus - DEBUG - Frame received:
2024-10-12 08:27:48,969 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:27:48,970 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:27:48,970 - DDModbus - DEBUG - Frame received:
....this continue until.....
2024-10-12 08:28:28,964 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:28:28,964 - DDModbus - DEBUG - Frame received:
2024-10-12 08:28:28,965 - Diematic - WARNING - Synchro timeout
2024-10-12 08:28:28,966 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:28:29,567 - Diematic - DEBUG - Bus status switched to MASTER after 40.601542949676514
2024-10-12 08:28:29,568 - DDModbus - DEBUG - Send read request: 0a030001003f556100
2024-10-12 08:28:29,768 - DDModbus - DEBUG - Answer received: 0a037e000000000030000a001b0006005300be8046000100030000000000af00aa003c0008ffff0003000f0000000000d200b9003c000800ef00070016006401c20000ffff000000c800b4003c000800e200070016006401c20000ffff0000000000000000000000000000000000000000000000000000022600000002021c0000196e000000
2024-10-12 08:28:29,769 - DDModbus - DEBUG - Answer valid
2024-10-12 08:28:29,769 - DDModbus - DEBUG - Send read request: 0a0300400040449500
2024-10-12 08:28:29,981 - DDModbus - DEBUG - Answer received: 0a038000010000000000000000000000000000000000000064024d8ccc2807091100000000000000000000000000000000000000000001000000000000000000000000006400000000000000000000004800000000000000000000000c000a0018000000008ccc000000000000024d00000000000203200000000000000000000f03e00824000000
2024-10-12 08:28:29,982 - DDModbus - DEBUG - Answer valid
2024-10-12 08:28:29,982 - DDModbus - DEBUG - Send read request: 0a0301800040455500
2024-10-12 08:28:30,199 - DDModbus - DEBUG - Answer received: 0a038000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000280001000000000000000000000000000000000064000e007800060002000000000000000009112807000038e9000000
2024-10-12 08:28:30,200 - DDModbus - DEBUG - Answer valid
2024-10-12 08:28:30,200 - DDModbus - DEBUG - Send read request: 0a0301c00017057f00
2024-10-12 08:28:30,314 - DDModbus - DEBUG - Answer received: 0a032e0000000000000000024d02378ccc0000000e00180000021d00000000006400000000ffff00008001800100008001dd57000000
2024-10-12 08:28:30,315 - DDModbus - DEBUG - Answer valid
2024-10-12 08:28:30,316 - __main__ - INFO - Publish :home/heater/boiler/status Online
2024-10-12 08:28:30,317 - __main__ - INFO - Publish :home/heater/boiler/date 2024-10-12T10:27:00+02:00
2024-10-12 08:28:30,317 - __main__ - INFO - Publish :home/heater/boiler/type 24
2024-10-12 08:28:30,318 - __main__ - INFO - Publish :home/heater/boiler/ctrl 48
2024-10-12 08:28:30,319 - __main__ - INFO - Publish :home/heater/boiler/ext/temp 8.3
2024-10-12 08:28:30,320 - __main__ - INFO - Publish :home/heater/boiler/temp 58.9
2024-10-12 08:28:30,320 - __main__ - INFO - Publish :home/heater/boiler/targetTemp 0.0
2024-10-12 08:28:30,321 - __main__ - INFO - Publish :home/heater/boiler/returnTemp 56.7
2024-10-12 08:28:30,322 - __main__ - INFO - Publish :home/heater/boiler/waterPressure 1.4
2024-10-12 08:28:30,323 - __main__ - INFO - Publish :home/heater/boiler/power 0
2024-10-12 08:28:30,324 - __main__ - INFO - Publish :home/heater/boiler/smokeTemp -327.6
2024-10-12 08:28:30,325 - __main__ - INFO - Publish :home/heater/boiler/ionizationCurrent 0.0
2024-10-12 08:28:30,326 - __main__ - INFO - Publish :home/heater/boiler/fanSpeed 0
2024-10-12 08:28:30,327 - __main__ - INFO - Publish :home/heater/boiler/burnerStatus 0
2024-10-12 08:28:30,328 - __main__ - INFO - Publish :home/heater/boiler/alarm {"id": 65535, "txt": "D\u00e9faut inconnu"}
2024-10-12 08:28:30,329 - __main__ - INFO - Publish :home/heater/boiler/hotWater/pump 0
2024-10-12 08:28:30,330 - __main__ - INFO - Publish :home/heater/boiler/hotWater/temp 54.0
2024-10-12 08:28:30,331 - __main__ - INFO - Publish :home/heater/boiler/hotWater/mode AUTO
2024-10-12 08:28:30,331 - __main__ - INFO - Publish :home/heater/boiler/hotWater/dayTemp 55.0
2024-10-12 08:28:30,332 - __main__ - INFO - Publish :home/heater/boiler/hotWater/nightTemp 10.0
2024-10-12 08:28:30,332 - __main__ - INFO - Publish :home/heater/boiler/zoneB/temp 23.9
2024-10-12 08:28:30,333 - __main__ - INFO - Publish :home/heater/boiler/zoneB/mode AUTO
2024-10-12 08:28:30,333 - __main__ - INFO - Publish :home/heater/boiler/zoneB/pump 0
2024-10-12 08:28:30,334 - __main__ - INFO - Publish :home/heater/boiler/zoneB/dayTemp 21.0
2024-10-12 08:28:30,334 - __main__ - INFO - Publish :home/heater/boiler/zoneB/nightTemp 18.5
2024-10-12 08:28:30,334 - __main__ - INFO - Publish :home/heater/boiler/zoneB/antiiceTemp 6.0
2024-10-12 08:28:30,335 - Diematic - DEBUG - Now :2024-10-12 08:28:30.334968+00:00
2024-10-12 08:28:30,335 - Diematic - DEBUG - Boiler :2024-10-12 10:27:00+02:00
2024-10-12 08:28:30,335 - Diematic - DEBUG - Drift :90.334968
2024-10-12 08:28:30,335 - Diematic - DEBUG - Drift Counter:2
2024-10-12 08:29:10,391 - Diematic - WARNING - Synchro timeout
2024-10-12 08:29:10,393 - __main__ - INFO - Publish :home/heater/boiler/status Offline
2024-10-12 08:29:10,394 - __main__ - INFO - Publish :home/heater/boiler/date
2024-10-12 08:29:10,395 - __main__ - INFO - Publish :home/heater/boiler/type
2024-10-12 08:29:10,396 - __main__ - INFO - Publish :home/heater/boiler/ctrl
2024-10-12 08:29:10,398 - __main__ - INFO - Publish :home/heater/boiler/ext/temp
2024-10-12 08:29:10,400 - __main__ - INFO - Publish :home/heater/boiler/temp
2024-10-12 08:29:10,403 - __main__ - INFO - Publish :home/heater/boiler/targetTemp
2024-10-12 08:29:10,404 - __main__ - INFO - Publish :home/heater/boiler/returnTemp
2024-10-12 08:29:10,406 - __main__ - INFO - Publish :home/heater/boiler/waterPressure
2024-10-12 08:29:10,408 - __main__ - INFO - Publish :home/heater/boiler/power
2024-10-12 08:29:10,410 - __main__ - INFO - Publish :home/heater/boiler/smokeTemp
2024-10-12 08:29:10,413 - __main__ - INFO - Publish :home/heater/boiler/ionizationCurrent
2024-10-12 08:29:10,415 - __main__ - INFO - Publish :home/heater/boiler/fanSpeed
2024-10-12 08:29:10,417 - __main__ - INFO - Publish :home/heater/boiler/burnerStatus
2024-10-12 08:29:10,419 - __main__ - INFO - Publish :home/heater/boiler/alarm
2024-10-12 08:29:10,421 - __main__ - INFO - Publish :home/heater/boiler/hotWater/pump
2024-10-12 08:29:10,423 - __main__ - INFO - Publish :home/heater/boiler/hotWater/temp
2024-10-12 08:29:10,424 - __main__ - INFO - Publish :home/heater/boiler/hotWater/mode
2024-10-12 08:29:10,426 - __main__ - INFO - Publish :home/heater/boiler/hotWater/dayTemp
2024-10-12 08:29:10,428 - __main__ - INFO - Publish :home/heater/boiler/hotWater/nightTemp
2024-10-12 08:29:10,429 - __main__ - INFO - Publish :home/heater/boiler/zoneB/temp
2024-10-12 08:29:10,431 - __main__ - INFO - Publish :home/heater/boiler/zoneB/mode
2024-10-12 08:29:10,433 - __main__ - INFO - Publish :home/heater/boiler/zoneB/pump
2024-10-12 08:29:10,434 - __main__ - INFO - Publish :home/heater/boiler/zoneB/dayTemp
2024-10-12 08:29:10,435 - __main__ - INFO - Publish :home/heater/boiler/zoneB/nightTemp
2024-10-12 08:29:10,436 - __main__ - INFO - Publish :home/heater/boiler/zoneB/antiiceTemp
2024-10-12 08:29:10,439 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:29:10,440 - DDModbus - DEBUG - Frame received:
2024-10-12 08:29:10,440 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:29:10,441 - Diematic - DEBUG - Bus status switched to SLAVE
2024-10-12 08:29:10,441 - DDModbus - DEBUG - Frame received:
2024-10-12 08:29:10,442 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:29:10,442 - DDModbus - DEBUG - Frame received:
2024-10-12 08:29:10,443 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:29:10,443 - DDModbus - DEBUG - Frame received:
2024-10-12 08:29:43,459 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:29:43,459 - DDModbus - DEBUG - Frame received:
2024-10-12 08:29:50,257 - DDModbus - DEBUG - Frame received:
2024-10-12 08:29:50,257 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:29:50,258 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:29:50,439 - DDModbus - DEBUG - Frame received:
2024-10-12 08:29:50,439 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:29:50,440 - Diematic - WARNING - Synchro timeout
2024-10-12 08:29:50,441 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:29:51,042 - Diematic - DEBUG - Bus status switched to MASTER after 40.6016206741333
2024-10-12 08:29:51,043 - DDModbus - DEBUG - Send read request: 0a030001003f556100
2024-10-12 08:29:51,245 - DDModbus - DEBUG - Answer received: 0a037e000000000030000a001d0006005400be8046000100030000000000af00aa003c0008ffff0003000f0000000000d200b9003c000800ef00070016006401c20000ffff000000c800b4003c000800e200070016006401c20000ffff0000000000000000000000000000000000000000000000000000022600000002021c0000e257000000
2024-10-12 08:29:51,247 - DDModbus - DEBUG - Answer valid
2024-10-12 08:29:51,248 - DDModbus - DEBUG - Send read request: 0a0300400040449500
2024-10-12 08:29:51,469 - DDModbus - DEBUG - Answer received: 0a038000010000000000000000000000000000000000000064024a8ccc2807091100000000000000000000000000000000000000000001000000000000000000000000006400000000000000000000004800000000000000000000000c000a0018000000008ccc000000000000024a00000000000203200000000000000000000f03e049a3000000
2024-10-12 08:29:51,472 - DDModbus - DEBUG - Answer valid
2024-10-12 08:29:51,473 - DDModbus - DEBUG - Send read request: 0a0301800040455500
2024-10-12 08:29:51,677 - DDModbus - DEBUG - Answer received: 0a038000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000280001000000000000000000000000000000000064000e007800060002000000000000000009112807000038e9000000
2024-10-12 08:29:51,679 - DDModbus - DEBUG - Answer valid
2024-10-12 08:29:51,680 - DDModbus - DEBUG - Send read request: 0a0301c00017057f00
2024-10-12 08:29:51,798 - DDModbus - DEBUG - Answer received: 0a032e0000000000000000024a02358ccc0000000e00180000021c00000000006400000000ffff000080018001000080011a3b000000
2024-10-12 08:29:51,799 - DDModbus - DEBUG - Answer valid
2024-10-12 08:29:51,801 - __main__ - INFO - Publish :home/heater/boiler/status Online
2024-10-12 08:29:51,802 - __main__ - INFO - Publish :home/heater/boiler/date 2024-10-12T10:29:00+02:00
2024-10-12 08:29:51,803 - __main__ - INFO - Publish :home/heater/boiler/type 24
2024-10-12 08:29:51,805 - __main__ - INFO - Publish :home/heater/boiler/ctrl 48
2024-10-12 08:29:51,806 - __main__ - INFO - Publish :home/heater/boiler/ext/temp 8.4
2024-10-12 08:29:51,807 - __main__ - INFO - Publish :home/heater/boiler/temp 58.6
2024-10-12 08:29:51,808 - __main__ - INFO - Publish :home/heater/boiler/targetTemp 0.0
2024-10-12 08:29:51,809 - __main__ - INFO - Publish :home/heater/boiler/returnTemp 56.5
2024-10-12 08:29:51,810 - __main__ - INFO - Publish :home/heater/boiler/waterPressure 1.4
2024-10-12 08:29:51,811 - __main__ - INFO - Publish :home/heater/boiler/power 0
2024-10-12 08:29:51,812 - __main__ - INFO - Publish :home/heater/boiler/smokeTemp -327.6
2024-10-12 08:29:51,813 - __main__ - INFO - Publish :home/heater/boiler/ionizationCurrent 0.0
2024-10-12 08:29:51,814 - __main__ - INFO - Publish :home/heater/boiler/fanSpeed 0
2024-10-12 08:29:51,815 - __main__ - INFO - Publish :home/heater/boiler/burnerStatus 0
2024-10-12 08:29:51,816 - __main__ - INFO - Publish :home/heater/boiler/alarm {"id": 65535, "txt": "D\u00e9faut inconnu"}
2024-10-12 08:29:51,817 - __main__ - INFO - Publish :home/heater/boiler/hotWater/pump 0
2024-10-12 08:29:51,818 - __main__ - INFO - Publish :home/heater/boiler/hotWater/temp 54.0
2024-10-12 08:29:51,819 - __main__ - INFO - Publish :home/heater/boiler/hotWater/mode AUTO
2024-10-12 08:29:51,820 - __main__ - INFO - Publish :home/heater/boiler/hotWater/dayTemp 55.0
2024-10-12 08:29:51,820 - __main__ - INFO - Publish :home/heater/boiler/hotWater/nightTemp 10.0
2024-10-12 08:29:51,821 - __main__ - INFO - Publish :home/heater/boiler/zoneB/temp 23.9
2024-10-12 08:29:51,822 - __main__ - INFO - Publish :home/heater/boiler/zoneB/mode AUTO
2024-10-12 08:29:51,822 - __main__ - INFO - Publish :home/heater/boiler/zoneB/pump 0
2024-10-12 08:29:51,823 - __main__ - INFO - Publish :home/heater/boiler/zoneB/dayTemp 21.0
2024-10-12 08:29:51,823 - __main__ - INFO - Publish :home/heater/boiler/zoneB/nightTemp 18.5
2024-10-12 08:29:51,824 - __main__ - INFO - Publish :home/heater/boiler/zoneB/antiiceTemp 6.0
2024-10-12 08:29:51,824 - Diematic - DEBUG - Now :2024-10-12 08:29:51.824562+00:00
2024-10-12 08:29:51,825 - Diematic - DEBUG - Boiler :2024-10-12 10:29:00+02:00
2024-10-12 08:29:51,825 - Diematic - DEBUG - Drift :51.824562
2024-10-12 08:30:31,881 - Diematic - WARNING - Synchro timeout
2024-10-12 08:30:31,882 - __main__ - INFO - Publish :home/heater/boiler/status Offline
2024-10-12 08:30:31,884 - __main__ - INFO - Publish :home/heater/boiler/date
2024-10-12 08:30:31,885 - __main__ - INFO - Publish :home/heater/boiler/type
2024-10-12 08:30:31,886 - __main__ - INFO - Publish :home/heater/boiler/ctrl
2024-10-12 08:30:31,887 - __main__ - INFO - Publish :home/heater/boiler/ext/temp
2024-10-12 08:30:31,889 - __main__ - INFO - Publish :home/heater/boiler/temp
2024-10-12 08:30:31,891 - __main__ - INFO - Publish :home/heater/boiler/targetTemp
2024-10-12 08:30:31,893 - __main__ - INFO - Publish :home/heater/boiler/returnTemp
2024-10-12 08:30:31,895 - __main__ - INFO - Publish :home/heater/boiler/waterPressure
2024-10-12 08:30:31,897 - __main__ - INFO - Publish :home/heater/boiler/power
2024-10-12 08:30:31,899 - __main__ - INFO - Publish :home/heater/boiler/smokeTemp
2024-10-12 08:30:31,901 - __main__ - INFO - Publish :home/heater/boiler/ionizationCurrent
2024-10-12 08:30:31,903 - __main__ - INFO - Publish :home/heater/boiler/fanSpeed
2024-10-12 08:30:31,905 - __main__ - INFO - Publish :home/heater/boiler/burnerStatus
2024-10-12 08:30:31,907 - __main__ - INFO - Publish :home/heater/boiler/alarm
2024-10-12 08:30:31,909 - __main__ - INFO - Publish :home/heater/boiler/hotWater/pump
2024-10-12 08:30:31,912 - __main__ - INFO - Publish :home/heater/boiler/hotWater/temp
2024-10-12 08:30:31,913 - __main__ - INFO - Publish :home/heater/boiler/hotWater/mode
2024-10-12 08:30:31,914 - __main__ - INFO - Publish :home/heater/boiler/hotWater/dayTemp
2024-10-12 08:30:31,916 - __main__ - INFO - Publish :home/heater/boiler/hotWater/nightTemp
2024-10-12 08:30:31,918 - __main__ - INFO - Publish :home/heater/boiler/zoneB/temp
2024-10-12 08:30:31,920 - __main__ - INFO - Publish :home/heater/boiler/zoneB/mode
2024-10-12 08:30:31,921 - __main__ - INFO - Publish :home/heater/boiler/zoneB/pump
2024-10-12 08:30:31,923 - __main__ - INFO - Publish :home/heater/boiler/zoneB/dayTemp
2024-10-12 08:30:31,925 - __main__ - INFO - Publish :home/heater/boiler/zoneB/nightTemp
2024-10-12 08:30:31,926 - __main__ - INFO - Publish :home/heater/boiler/zoneB/antiiceTemp
2024-10-12 08:30:31,929 - Diematic - WARNING - Init Link with Regulator
2024-10-12 08:30:31,930 - DDModbus - DEBUG - Frame received:
2024-10-12 08:30:31,931 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:30:31,931 - Diematic - DEBUG - Bus status switched to SLAVE
2024-10-12 08:30:31,932 - DDModbus - DEBUG - Frame received:
2024-10-12 08:30:31,932 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:30:31,933 - DDModbus - DEBUG - Frame received:
2024-10-12 08:30:31,934 - DDModbus - WARNING - Received Frame Length Error
2024-10-12 08:30:31,936 - DDModbus - DEBUG - Frame received:
2024-10-12 08:30:31,937 - DDModbus - WARNING - Received Frame Length Error
I set the log level to CRITICAL to limit the log size.
Regards,
Pawel
