I have managed to get it running with my De Dietrich GT1200 using a Diematic 3 FM16 controller and a USR-W610 in transparent TCP server mode.
The connection, synchronization, MQTT publishing are working. However, my controller consistently fails on the final register block:
The first three blocks return valid frames every cycle.
For the ease of debugging I run Diematic32MQTT.py locally on my pc, later i plan to run it as app in HA.
Here is fragment of the log (i included 3 cycles).
2026-07-10 12:41:08,053 - Diematic - DEBUG - Bus status switched to MASTER after 5.233271837234497
2026-07-10 12:41:08,055 - Diematic - INFO - ModBus Master Slave Synchro OK
2026-07-10 12:41:08,056 - DDModbus - DEBUG - Send read request: 0a030001003f556100
2026-07-10 12:41:08,321 - DDModbus - DEBUG - Answer received: 0a037eb80a000000d2000c0029000500f600fa001e000100040001000000aa00a00032000100ce0005001d80143b0e00a00032003c0001ffff0003000e00c801c20000012a0a0200c800a0003c0001ffff0003000700c801f40000ffff0b00000c000000180b0000ca850f000093940f2c0b0009000b00022600000004019d00000352000000
2026-07-10 12:41:08,323 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:08,325 - DDModbus - DEBUG - Send read request: 0a0300400040449500
2026-07-10 12:41:08,789 - DDModbus - DEBUG - Answer received: 0a0380000100001a009b0a00960096012c02ee0028260000280231002a44593353000000000a00001a00bc0a873b0e080000000100000000010000000000000000000000640a020000000000ea050b00f500000f01000a000a9394000a0007001a0f0000000000001c0000000002310b00000000020320090000ca850f00b4000f03e0d20a000000
2026-07-10 12:41:08,791 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:08,792 - DDModbus - DEBUG - Send read request: 0a0301800040455500
2026-07-10 12:41:09,240 - DDModbus - DEBUG - Answer received: 0a038000b80a0000ca850fef9809000a0000b0090000ef98b60a0000ef980ef600080002000000c50a0000ef980e0070090c020000d30a0000ef980e0a0000000200000000df00000200ee0a00000000640b0000ee0a02002800000001000000000000000000000000000000284a0100784a0100000000090b0232002a7f017f0000bdbcdc000000
2026-07-10 12:41:09,241 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:09,242 - DDModbus - DEBUG - Send read request: 0a0301c00017057f00
2026-07-10 12:41:11,757 - DDModbus - WARNING - No answer to masterReadAnalog
2026-07-10 12:41:11,759 - Diematic - WARNING - ModBus Master Slave Synchro Error
2026-07-10 12:41:12,970 - DDModbus - DEBUG - Frame received: 25030065000192f100
2026-07-10 12:41:12,972 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:12,974 - Diematic - DEBUG - Bus status switched to SLAVE
2026-07-10 12:41:13,320 - DDModbus - DEBUG - Frame received: 26030065000192c200
2026-07-10 12:41:13,321 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:13,640 - DDModbus - DEBUG - Frame received: 270300650001931300
2026-07-10 12:41:13,641 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:14,015 - DDModbus - DEBUG - Frame received: 14030065000196d000
2026-07-10 12:41:14,017 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:14,320 - DDModbus - DEBUG - Frame received: 150300650001970100
2026-07-10 12:41:14,321 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:14,679 - DDModbus - DEBUG - Frame received: 160300650001973200
2026-07-10 12:41:14,681 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:15,010 - DDModbus - DEBUG - Frame received: 17030065000196e300
2026-07-10 12:41:15,013 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:15,350 - DDModbus - DEBUG - Frame received: 180300650001961c00
2026-07-10 12:41:15,351 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:15,680 - DDModbus - DEBUG - Frame received: 19030065000197cd00
2026-07-10 12:41:15,682 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:16,040 - DDModbus - DEBUG - Frame received: 1a030065000197fe00
2026-07-10 12:41:16,042 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:16,360 - DDModbus - DEBUG - Frame received: 1b0300650001962f00
2026-07-10 12:41:16,363 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:16,710 - DDModbus - DEBUG - Frame received: 1c0300650001979800
2026-07-10 12:41:16,714 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:17,040 - DDModbus - DEBUG - Frame received: 1d0300650001964900
2026-07-10 12:41:17,042 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:17,390 - DDModbus - DEBUG - Frame received: 1e0300650001967a00
2026-07-10 12:41:17,392 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:17,720 - DDModbus - DEBUG - Frame received: 1f030065000197ab00
2026-07-10 12:41:17,721 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:18,230 - Diematic - DEBUG - Bus status switched to MASTER after 5.256027936935425
2026-07-10 12:41:18,230 - Diematic - INFO - ModBus Master Slave Synchro OK
2026-07-10 12:41:18,231 - DDModbus - DEBUG - Send read request: 0a030001003f556100
2026-07-10 12:41:18,580 - DDModbus - DEBUG - Answer received: 0a037eb80a000000d2000c0029000500f500fa001e000100040001000000aa00a00032000100cf0005001d80143b0e00a00032003c0001ffff0003000e00c801c20000012a0a0200c800a0003c0001ffff0003000700c801f40000ffff0b0000bd0f0000000000001c0b0000ca850f0b0000000000002a022600000004019d0000b1ea000000
2026-07-10 12:41:18,581 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:18,582 - DDModbus - DEBUG - Send read request: 0a0300400040449500
2026-07-10 12:41:19,050 - DDModbus - DEBUG - Answer received: 0a038000010a0000ca850f00960096012c02ee0028260000280231002a44593353000000000000c50a0000ef980e0070090c02000000000001000000000000000000000064df0afe0200ee0a00000000f5000000ee000a000aee0a000a0007001a1e005601660b00000000000002312b0f3f04000203200a00000410002005000f03e0e180000000
2026-07-10 12:41:19,052 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:19,054 - DDModbus - DEBUG - Send read request: 0a0301800040455500
2026-07-10 12:41:19,530 - DDModbus - DEBUG - Answer received: 0a0380b80a00001a009b0a873b0e080000000100b80a0000000009000000ad0a28004000d90a00001a00bc0a873b0e080000000100d90a00000000d90a0000ef980e3a0ed90a020000000000ea050b0000140b0000939400280000000100000000000000000000000000000028939400780b0009000b0000160231002a980e1d0b0000cc57000000
2026-07-10 12:41:19,531 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:19,533 - DDModbus - DEBUG - Send read request: 0a0301c00017057f00
2026-07-10 12:41:22,034 - DDModbus - WARNING - No answer to masterReadAnalog
2026-07-10 12:41:22,035 - Diematic - WARNING - ModBus Master Slave Synchro Error
2026-07-10 12:41:23,100 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:23,101 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:23,101 - Diematic - DEBUG - Bus status switched to SLAVE
2026-07-10 12:41:23,380 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:23,381 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:23,600 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:23,602 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:23,820 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:23,823 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:24,190 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:24,192 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:24,410 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:24,411 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:24,656 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:24,658 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:24,801 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:24,803 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:25,130 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:25,131 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:25,340 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:25,340 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:25,500 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:25,501 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:25,711 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:25,713 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:25,930 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:25,931 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:26,070 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:26,071 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:26,212 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:26,213 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:26,420 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:26,421 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:26,760 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:26,762 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:26,920 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:26,921 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:27,130 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:27,131 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:27,350 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:27,351 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:27,730 - DDModbus - DEBUG - Frame received: 0b1001b40001020000d38400
2026-07-10 12:41:27,731 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:28,234 - Diematic - DEBUG - Bus status switched to MASTER after 5.132521867752075
2026-07-10 12:41:28,236 - Diematic - INFO - ModBus Master Slave Synchro OK
2026-07-10 12:41:28,237 - DDModbus - DEBUG - Send read request: 0a030001003f556100
2026-07-10 12:41:28,492 - DDModbus - DEBUG - Answer received: 0a037eb80a000000d2000c0029000500f500fa001e000100040001000000aa00a00032000100ce0005001d8014000000a00032003c0001ffff0003000e00c801c20000012ad40a00c800a0003c0001ffff0003000700c801f40000ffff0b0000280000007d0b00001c0b0000ca850f0e080f0b0000ef98022600000004019d0000f573000000
2026-07-10 12:41:28,494 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:28,495 - DDModbus - DEBUG - Send read request: 0a0300400040449500
2026-07-10 12:41:28,950 - DDModbus - DEBUG - Answer received: 0a0380000100001a009b0a00960096012c02ee0028260000280231002a44593353000000000a00001a00bc0a873b0e080000000100000000010000000000000000000000640a020000000000ea050b00f500000f01000a000a9394000a0007001a0000008c0b7e0b1c00000000023128004000000203201a000b0b873b0e08000f03e017a5000000
2026-07-10 12:41:28,950 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:28,951 - DDModbus - DEBUG - Send read request: 0a0301800040455500
2026-07-10 12:41:29,411 - DDModbus - DEBUG - Answer received: 0a0380b80a00001a009b0a873b0e080000000100b80a0000000000000000ad0a28004000d90a00001a00bc0a873b0e080000000100d90a00000000d9cb0a28004000f70a00001a00da0a873b0e080000000100f70a000000280000000100000000000000000000000000000028000c0078000a0007001a00280231002a0b260b000000e840000000
2026-07-10 12:41:29,411 - DDModbus - DEBUG - Answer valid
2026-07-10 12:41:29,412 - DDModbus - DEBUG - Send read request: 0a0301c00017057f00
2026-07-10 12:41:31,926 - DDModbus - WARNING - No answer to masterReadAnalog
2026-07-10 12:41:31,929 - Diematic - WARNING - ModBus Master Slave Synchro Error
2026-07-10 12:41:33,130 - DDModbus - DEBUG - Frame received: 20030065000192a400
2026-07-10 12:41:33,132 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:33,134 - Diematic - DEBUG - Bus status switched to SLAVE
2026-07-10 12:41:33,460 - DDModbus - DEBUG - Frame received: 210300650001937500
2026-07-10 12:41:33,461 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:33,710 - DDModbus - DEBUG - Frame received: 220300650001934600
2026-07-10 12:41:33,713 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:34,021 - DDModbus - DEBUG - Frame received: 230300650001929700
2026-07-10 12:41:34,023 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:34,280 - DDModbus - DEBUG - Frame received: 240300650001932000
2026-07-10 12:41:34,282 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:34,602 - DDModbus - DEBUG - Frame received: 25030065000192f100
2026-07-10 12:41:34,603 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:34,962 - DDModbus - DEBUG - Frame received: 26030065000192c200
2026-07-10 12:41:34,962 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:35,280 - DDModbus - DEBUG - Frame received: 270300650001931300
2026-07-10 12:41:35,281 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:35,630 - DDModbus - DEBUG - Frame received: 14030065000196d000
2026-07-10 12:41:35,632 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:35,951 - DDModbus - DEBUG - Frame received: 150300650001970100
2026-07-10 12:41:35,951 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:36,322 - DDModbus - DEBUG - Frame received: 160300650001973200
2026-07-10 12:41:36,324 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:36,642 - DDModbus - DEBUG - Frame received: 17030065000196e300
2026-07-10 12:41:36,645 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:36,991 - DDModbus - DEBUG - Frame received: 180300650001961c00
2026-07-10 12:41:36,993 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:37,300 - DDModbus - DEBUG - Frame received: 19030065000197cd00
2026-07-10 12:41:37,302 - DDModbus - DEBUG - slave address is not matching expected list
2026-07-10 12:41:37,661 - DDModbus - DEBUG - Frame received: 1a030065000197fe00
2026-07-10 12:41:37,661 - DDModbus - DEBUG - slave address is not matching expected list
