Dead USB Z wave stick
My daughter thought she’d bend my Aeotec USB Z wave stick :frowning:
I’ve waited for a new one, plugged it in and found that my devices aren’t working. It would seem the devices are learned to the old broken bent stick?
I tried learning on a new device, that wasn’t on the old stick. This has taken address 4, and now thinks it’s the wrong type of device.
Any ideas how to fix this mess, and delete all my Z wave devices so I can start again readding them?
Thanks for any help!
A device is associated to a controller (your bended stick yes). If you have a new controller (stick) you need to restore a backup to stick (ha cannot do this natively!) or you need to repair all your devices… and if the device was paired to the previous stick you need to remove it from there (disassociate). Disassociation can be done from any zwave controller or by following the specific reset of a specific zwave device.
Overall: good luck, you’re screwed without a proper zwave backup
Fix old stick
Back it up
Restore backup to new stick
OR
Start from scratch
Urgh haha. I managed to clean up by deleting the Z wave add on. I was then able to learn the new device. That just leaves me with trying to default the other devices so they can be learnt.
per device follow the normal “exclusion” process on the NEW controller. exclusion does not care about the original controller. after that you can include them again. Although exclusion should factory reset, it is always good to find the per device manual to additionally factory reset separately.
