After a long time I finally have started to work with my home automation system again.
I have moved everything to a new computer and updated to HAOS and restore a backup.
Zwave nodes that worked before in old system is shown up as Zwave devices but I can’t access them.
Now I’m running Zwave JS.
I have tried to power off/on devices, factory reset and so on…
But nothing help.
I can add other new Zwave devices to the system and controlling them.
Meaning that my Zwave network seems to work.
How can I get this old Zwave devices to work again?
if you did factory reset on the devices, youĺl need to ‘remove dead nodes’ and start inclusion again. Factory reset sometimes require a second reset i’ve noticed. Then after second reset the inclusion works when it didnt after a first reset. Sounds weird, but would give it a try. And also get them close to the controller when doing inclusion.
I have removed the switch from the wall and put it close to the controller.
Have tried to make factory reset several times on the switch.
But I don’t think that the led on the switch are shine as the manual writes!
Therefore I’m not 100% shore that I have made a correct reset on the switch!
I have tried many times.
But I were able to remove one dead node from the Zwave network, I’m not sure if it’s the switch/node that I’m currently working/trying with. Because I have several Zwave nodes that have the same behavior and I can’t see the different of those!
Anyway I have tried to include the switch again to the network. By pressing the B-button three times and the Controller makes a question the the device/switch. But the switch will not be added, nothing happens after that the Controller has been thinking for a time.
