I’m trying to debug Ad scripts using something better than simple log.
I have a rpi4 8gb with hassOS, the AD add-on and also Studio Code One. I tried to setup the debug system, but I failed.
I tried to setup this way
system_packages: []
python_packages:
- debugpy
init_commands:
- python3 -m debugpy --listen 0.0.0.0:5678 -m appdaemon
but I have errors.
ERROR: Error accessing configuration: No valid configuration file found in default locations: [‘/root/.homeassistant’, ‘/etc/appdaemon’, ‘/conf’]
[18:46:07] FATAL: Failed executing init command: python3 -m debugpy --listen 0.0.0.0:5678 -m appdaemon
s6-rc: warning: unable to start service init-appdaemon: command exited 1
I also tried to skip the init command and setting
debugpy.listen((“0.0.0.0”, 5678 ))
but when I try to connect to it using this launch.json
"version": "0.2.0",
"configurations": [
"name": "Attach to AppDaemon",
"type": "debugpy",
"request": "attach",
"connect": {
"host": "homeassistant.local",
"port": 5678
"justMyCode": true
It can’t connect
Do you know what I could try or how to set it up?
