DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found:
I keep seeing this in my Logs DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found:
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/influxdb/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/configurator/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/climate/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/system_log/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/zone/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/http/translations/en.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/websocket_api/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/onboarding/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/webhook/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/config/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/switch/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/persistent_notification/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/frontend/translations/en.json
2020-08-01 08:51:45 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/utility_meter/translations/en.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/automation/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/notify/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /config/custom_components/entity_controller/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/search/translations/en.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/calendar/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/script/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/google/translations/en.json
2020-08-01 08:51:45 DEBUG (SyncWorker_5) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/influxdb/translations/en.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/timer/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/met/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/input_boolean/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/input_select/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/alexa/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/cloud/translations/en-GB.json
2020-08-01 08:51:45 DEBUG (SyncWorker_4) [homeassistant.util.json] JSON file not found: /usr/src/homeassistant/homeassistant/components/life360/translations/en-GB.json
Any thoughts?
