My Adaptive Lighting has been buggy lately. I’m getting a series of errors in my logger about SQL queries failing, although they succeed in phpMyAdmin.
Any idea on what could be going on and how to fix this? I don’t get the need to run ROLLBACK. Process List shows pretty clean.
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:218
Integration: Recorder (documentation, issues)
First occurred: 1:12:21 PM (75 occurrences)
Last logged: 8:55:47 PM
Error executing query: (MySQLdb.OperationalError) (2013, 'Lost connection to server during query') [SQL: SELECT state_attributes.attributes_id, state_attributes.shared_attrs FROM state_attributes WHERE state_attributes.hash IN (%s)] [parameters: (2748489755,)] (Background on this error at: https://sqlalche.me/e/20/e3q8)
Error executing query: Can't reconnect until invalid transaction is rolled back. Please rollback() fully before proceeding (Background on this error at: https://sqlalche.me/e/20/8s2b)
Error executing query: (MySQLdb.OperationalError) (2002, "Can't connect to server on 'core-mariadb' (115)") (Background on this error at: https://sqlalche.me/e/20/e3q8)
Error executing query: (MySQLdb.OperationalError) (2013, 'Lost connection to server during query') [SQL: SELECT state_attributes.attributes_id, state_attributes.shared_attrs FROM state_attributes WHERE state_attributes.hash IN (%s)] [parameters: (942416054,)] (Background on this error at: https://sqlalche.me/e/20/e3q8)
Error executing query: (MySQLdb.OperationalError) (2013, 'Lost connection to server during query') [SQL: SELECT state_attributes.attributes_id, state_attributes.shared_attrs FROM state_attributes WHERE state_attributes.hash IN (%s)] [parameters: (1010108519,)] (Background on this error at: https://sqlalche.me/e/20/e3q8)
And specific error from Adaptive Lighting:
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:890
First occurred: 1:12:21 PM (20 occurrences)
Unhandled database error while processing task <Event state_changed[L]: entity_id=sensor.diskless_bond0_rx, old_state=<state sensor.diskless_bond0_rx=0.00252543786488741; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Diskless - bond0 RX @ 2026-09-22T18:18:31.558809-07:00>, new_state=<state sensor.diskless_bond0_rx=0.00399056603773585; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Diskless - bond0 RX @ 2026-09-22T18:18:33.838954-07:00>>
Unhandled database error while processing task <Event state_changed[L]: entity_id=sensor.diskless_bond0_tx, old_state=<state sensor.diskless_bond0_tx=0.00417347789824854; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Diskless - bond0 TX @ 2026-09-22T18:18:31.558872-07:00>, new_state=<state sensor.diskless_bond0_tx=0.00643138936535163; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Diskless - bond0 TX @ 2026-09-22T18:18:33.839106-07:00>>
Unhandled database error while processing task <Event state_changed[L]: entity_id=sensor.samsung_odyssey_g95_rx, old_state=<state sensor.samsung_odyssey_g95_rx=3.30578512396694e-05; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Samsung Odyssey G95 RX @ 2026-09-22T18:18:22.132107-07:00>, new_state=<state sensor.samsung_odyssey_g95_rx=0.0; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Samsung Odyssey G95 RX @ 2026-09-22T18:18:33.839760-07:00>>
Unhandled database error while processing task <Event state_changed[L]: entity_id=sensor.blank_card_rx, old_state=<state sensor.blank_card_rx=0.000667497921862012; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Blank Card RX @ 2026-09-22T20:55:37.542694-07:00>, new_state=<state sensor.blank_card_rx=0.00756135770234987; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Blank Card RX @ 2026-09-22T20:55:44.001622-07:00>>
Unhandled database error while processing task <Event state_changed[L]: entity_id=sensor.blank_card_tx, old_state=<state sensor.blank_card_tx=0.000117206982543641; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Blank Card TX @ 2026-09-22T20:55:37.542877-07:00>, new_state=<state sensor.blank_card_tx=0.0051644908616188; state_class=measurement, unit_of_measurement=MB/s, device_class=data_rate, friendly_name=Blank Card TX @ 2026-09-22T20:55:44.001979-07:00>>
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 144, in __init__
self._dbapi_connection = engine.raw_connection()
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 3319, in raw_connection
return self.pool.connect()
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/pool/base.py", line 448, in connect
return _ConnectionFairy._checkout(self)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/pool/base.py", line 1272, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/pool/base.py", line 717, in checkout
with util.safe_reraise():
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/util/langhelpers.py", line 122, in __exit__
raise exc_value.with_traceback(exc_tb)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/pool/base.py", line 715, in checkout
dbapi_connection = rec.get_connection()
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/pool/base.py", line 866, in get_connection
self.__connect()
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/pool/base.py", line 900, in __connect
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/pool/base.py", line 896, in __connect
self.dbapi_connection = connection = pool._invoke_creator(self)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/engine/create.py", line 667, in connect
return dialect.connect(*cargs_tup, **cparams)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/engine/default.py", line 630, in connect
return self.loaded_dbapi.connect(*cargs, **cparams) # type: ignore[no-any-return] # NOQA: E501
File "/usr/local/lib/python3.14/site-packages/MySQLdb/__init__.py", line 121, in Connect
return Connection(*args, **kwargs)
File "/usr/local/lib/python3.14/site-packages/MySQLdb/connections.py", line 206, in __init__
super().__init__(*args, **kwargs2)
MySQLdb.OperationalError: (2002, "Can't connect to server on 'core-mariadb' (115)")
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 890, in _process_one_task_or_event_or_recover
self._process_one_event(task)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1037, in _process_one_event
self._process_state_changed_event_into_session(event)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1129, in _process_state_changed_event_into_session
elif metadata_id := states_meta_manager.get(entity_id, session, True):
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/states_meta.py", line 59, in get
return self.get_many((entity_id,), session, from_recorder)[entity_id]
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/states_meta.py", line 109, in get_many
for metadata_id, entity_id in execute_stmt_lambda_element(
session, find_states_metadata_ids(missing_chunk)
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 211, in execute_stmt_lambda_element
executed = session.execute(stmt)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/orm/session.py", line 2373, in execute
return self._execute_internal(
statement,
...<4 lines>...
_add_event=_add_event,
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/orm/session.py", line 2261, in _execute_internal
conn = self._connection_for_bind(bind)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/orm/session.py", line 2113, in _connection_for_bind
return trans._connection_for_bind(engine, execution_options)
File "<string>", line 2, in _connection_for_bind
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/orm/state_changes.py", line 137, in _go
ret_value = fn(self, *arg, **kw)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/orm/session.py", line 1191, in _connection_for_bind
conn = bind.connect()
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 3295, in connect
return self._connection_cls(self)
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 146, in __init__
Connection._handle_dbapi_exception_noconnection(
err, dialect, engine
File "/usr/local/lib/python3.14/site-packages/sqlalchemy/engine/base.py", line 2450, in _handle_dbapi_exception_noconnection
raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
self.__connect()
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (2002, "Can't connect to server on 'core-mariadb' (115)")
