I don’t know why I was sending messages to my phone for debugging. Guess I was lazy. In any case, use persistent notifications to get an alert in the “bell” at the top of the screen.
Example: I was having issues with my service not working. I was getting the wrong number which is at the end of the trigger. Instead of using regex, I was lazy and just using the index ala object_id[15:]
. I had the wrong index number, so I just added the following to my automation to spit out the codeslot
value until I found the correct index. I decided to keep the notification to notify the user that they have to take an addition action.
- service: persistent_notification.create
data_template:
title: "LOCK MANAGER"
message: >-
{% set object_id = trigger.to_state.object_id %}
{% set codeslot = object_id[15:] %}
{{ 'You changed the PIN for code ' + codeslot | string + '. Please enable it in order to make it active.'}}
Hope this helps
