ive recently moved all my nodes from openmqtt gateway to ESPhome, the last hurdle is 1 RF power socket and 3 RF light switches, i cant get the receiver attached to a different node to pick up the transmitted code (the RF codes from my door contacts are picked up fine) i thought i may have fried the transmitter at first but i connected to a PI i have laying around and it works just fine, picked up by the receiver and controls the RF switches and sockets.
When i used this setup with Openmqtt gateway i could use the 7 digit decimal code but i understand thats not possible with ESPhome and I have to use the binary.
My code is below, this is just a test but the binary code is correct as I have the original RF remote for that device.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "BTHub6-7TCR"
password: "tVC67mJaUtgX"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
remote_transmitter:
pin: D7
# RF uses a 100% carrier signal
carrier_duty_percent: 100%
switch:
name: RF Power Button
turn_on_action:
- remote_transmitter.transmit_rc_switch_raw:
code: '000101010101010111000011'
protocol: 7
turn_off_action:
code: '000101010101010111001100'
protocol: 7
i’m basically asking if there is a way to send the decimal code?
thanks
