Hi. After a few hours of trials I manage to add conbee II to home assistant
and connect a water leak sensor to the phoscon getaway.
although I can see in the integrations the deconz there is no sensor available in fronted
and in states again no binary sensors
in the logs I get “Invalid key for deCONZ at 172.xx.x.x”
and “Error connecting with deCONZ gateway”
this is the configuration
"device": "/dev/ttyACM0",
"vnc_password": ""
libpng warning: iCCP: known incorrect sRGB profile
This plugin does not support propagateSizeHints()
00:07:32:482 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
00:07:32:559 CTRL. 3.16.200:07:32:661 dev /dev/ttyAMA0
00:07:32:661 COM: /dev/ttyACM0 / serialno: DE2122523
00:07:32:661 COM: --dev: /dev/ttyACM0 (ConBee II)
00:07:32:661 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
00:07:32:884 parent process bash
00:07:32:884 gw run mode: docker/hassio
00:07:32:884 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
00:07:32:884 sd-card cid: 1b534d454231515430ffffffff01346b
00:07:32:886 DB sqlite version 3.16.2
00:07:32:888 DB PRAGMA page_count: 30
00:07:32:888 DB PRAGMA page_size: 4096
00:07:32:888 DB PRAGMA freelist_count: 0
00:07:32:888 DB file size 122880 bytes, free pages 0
00:07:32:888 DB PRAGMA user_version: 6
00:07:32:888 DB cleanup
00:07:32:889 DB create temporary views
00:07:32:900 don't close database yet, keep open for 900 seconds
00:07:32:901 started websocket server at port 40860
00:07:32:910 found node plugin: libde_rest_plugin.so - REST API Plugin
00:07:32:916 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
00:07:36:947 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
00:07:36:982 dev /dev/ttyAMA0
00:07:36:982 COM: /dev/ttyACM0 / serialno: DE2122523
00:07:36:982 COM: --dev: /dev/ttyACM0 (ConBee II)
00:07:37:061 Device firmware version 0x264A0700
00:07:37:102 unlocked max nodes: 200
00:07:37:194 Device protocol version: 0x010B
00:07:37:205 new node - ext: 0x00212effff04e418, nwk: 0x0000
00:07:37:278 SensorNode 2 set node 0x00158d000357d268
00:07:37:373 Current channel 15
00:07:37:391 CTRL ANT_CTRL 0x03
00:07:37:427 Device protocol version: 0x010B
00:07:37:482 Current channel 15
00:07:37:500 CTRL ANT_CTRL 0x03
00:07:37:709 dev /dev/ttyAMA0
00:07:37:709 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26490700.bin.GCF
00:07:37:710 GW firmware version: 0x264a0700
00:07:37:710 GW firmware version is up to date: 0x264a0700
00:07:38:264 New websocket 192.168.1.3:60171 (state: 3)
00:07:38:607 Announced to internet
00:07:38:607 discovery server date: Sun, 13 Oct 2019 21:07:38 GMT
00:07:38:607 local time seems to be ok
00:07:38:607 discovery found version 2.04.35 for update channel stable
00:07:40:428 New websocket 192.168.1.3:60172 (state: 3)
00:07:58:004 New websocket 192.168.1.3:60180 (state: 3)
00:07:59:330 Websocket disconnected 192.168.1.3:60180 (state: 0)
00:08:02:893 scan skip host .8
00:08:08:959 New websocket 192.168.1.3:60182 (state: 3)
00:08:11:509 Websocket disconnected 192.168.1.3:60182 (state: 0)
00:08:14:658 scan finished
00:08:32:472 Current channel 15
00:08:32:482 Device TTL 4232 s flags: 0x7
00:09:32:470 Current channel 15
00:09:32:480 Device TTL 4171 s flags: 0x7
00:10:32:465 Current channel 15
00:10:32:471 Device TTL 4111 s flags: 0x7
00:11:01:953 send permit join, duration: 59
00:11:06:020 CTRL skip polling while permit join is set
00:11:06:118 no button map for: lumi.sensor_wleak.aq1 ep: 0x01 cl: 0x0000 cmd: 0x0A pl[0]: 005
00:11:06:118 ZCL attribute report 0x00158D000357D268 for cluster 0x0000, ep 0x01
00:11:06:118 0x00158D000357D268 skip Xiaomi attribute 0x0000
00:11:06:118 0x00158D000357D268 extract Xiaomi special attribute 0xFF01
00:11:06:118 01 battery 3055 (0x0BEF)
00:11:06:118 03 temperature 29 °C
00:11:06:118 04 unknown 5032 (0x13A8)
00:11:06:118 05 RSSI dB (?) 66 (0x0042)
00:11:06:118 06 LQI (?) 262144 (0x0000040000)
00:11:06:119 08 unknown 516 (0x0204)
00:11:06:119 0a unknown 0 (0x0000)
00:11:06:119 64 on/off 0
00:11:06:613 CTRL skip polling while permit join is set
00:11:32:470 Current channel 15
00:11:32:480 Device TTL 4051 s flags: 0x7
00:11:37:500 dev /dev/ttyAMA0
00:11:37:501 GW firmware version: 0x264a0700
00:11:37:501 GW firmware version is up to date: 0x264a0700
00:11:57:912 Websocket disconnected 192.168.1.3:60171 (state: 0)
00:12:01:556 Search sensors done
00:12:03:953 send permit join, duration: 59
00:12:26:664 Websocket disconnected 192.168.1.3:60172 (state: 0) >
any ideas/help to short it out?
