deCONZ and the Heiman HS1HT-M
Good Evening!
I’m using a deCONZ USB-Stick successfully with several Devices. Some days ago the Heiman HS1HT-M stopped working. The UI shows 100% Battery state and that the Device is “on” (on is True). But the Device does not report new Data.
The Device and it’s Sensors are not listed in the deCONZ-Webfrontend; they never were and only appeared on the Home Assistant Frontend. Strange, hu?
How can i investigate the Problem?
Kind Regards,
Grr… Argh…
Enable debug for deconz, follow explanation in component documentation.
See what information comes from deconz in the logs
