I’ve problems to get my deconz devices to home assistant. I add the ConBee stick to the raspberry pi 3B+ port, install the deconz app and change the needed config to “device”: “/dev/ttyACM0”. Then I go to the Webpage (Phoscon App) and load my backup. If I now go to the Integration page and click on configure the Deconz zigbee Gateway (previously I press the “connect app” button in phoscon) then the deconz zigbee gateway with 00000000000000 appear under “configured”. But there are no devices in there. In the Phoscon webpage I can see all my bulbs and switches. I tried to delete and reconfigure it but with same results . If I dont load my backup, then the gatway and daylight appears as devices.
This is my deconz log:
20:31:57:883 gateway unlocked 20:32:16:052 no button handler for: RWL021 ep: 0x02 cl: 0x0001 cmd: 0x0A pl[0]: 021 20:32:16:052 ZCL attribute report 0x0017880104F75F49 for cluster 0x0001, ep 0x02 20:32:43:840 Current channel 25 20:32:43:849 Device TTL 3279 s flags: 0x7 20:32:57:819 gateway locked 20:33:36:022 no button map for: SML001 ep: 0x02 cl: 0x0402 cmd: 0x0A pl[0]: 000 20:33:36:022 ZCL attribute report 0x0017880102103BE6 for cluster 0x0402, ep 0x02 20:33:43:839 Current channel 25 20:33:43:849 Device TTL 3219 s flags: 0x7 20:33:47:149 no button map for: SML001 ep: 0x02 cl: 0x0406 cmd: 0x0A pl[0]: 000 20:33:47:149 ZCL attribute report 0x001788010210933B for cluster 0x0406, ep 0x02 20:33:47:168 no button map for: SML001 ep: 0x02 cl: 0x0400 cmd: 0x0A pl[0]: 000 20:33:47:168 ZCL attribute report 0x001788010210933B for cluster 0x0400, ep 0x02 20:34:03:615 0xAC17 seems to be a zombie recv errors 6 20:34:03:616 LightNode removed 0x000b57fffe88fca1 20:34:03:616 Node zombie state changed 0x000b57fffe88fca1 20:34:21:376 0x9DB6 seems to be a zombie recv errors 6 20:34:21:376 LightNode removed 0x000b57fffe90176b 20:34:21:376 Node zombie state changed 0x000b57fffe90176b 20:34:43:838 Current channel 25 20:34:43:847 Device TTL 3159 s flags: 0x7 20:35:09:349 no button handler for: RWL020 ep: 0x02 cl: 0x0001 cmd: 0x0A pl[0]: 021 20:35:09:349 ZCL attribute report 0x00178801103E77D9 for cluster 0x0001, ep 0x02 20:35:10:983 no button map for: SML001 ep: 0x02 cl: 0x0406 cmd: 0x0A pl[0]: 000 20:35:10:983 ZCL attribute report 0x0017880102103BE6 for cluster 0x0406, ep 0x02 20:35:11:028 no button map for: SML001 ep: 0x02 cl: 0x0400 cmd: 0x0A pl[0]: 000 20:35:11:028 ZCL attribute report 0x0017880102103BE6 for cluster 0x0400, ep 0x02 20:35:43:837 Current channel 25 20:35:43:847 Device TTL 3099 s flags: 0x7 20:35:49:866 dev /dev/ttyAMA0 20:35:49:866 GW firmware version: 0x26490700 20:35:49:866 GW firmware version is up to date: 0x26490700 20:36:18:774 no button handler for: RWL020 ep: 0x02 cl: 0x0001 cmd: 0x0A pl[0]: 021 20:36:18:774 ZCL attribute report 0x00178801103392BD for cluster 0x0001, ep 0x02 20:36:19:213 no button map for: SML001 ep: 0x02 cl: 0x0402 cmd: 0x0A pl[0]: 000 20:36:19:213 ZCL attribute report 0x001788010210933B for cluster 0x0402, ep 0x02 20:36:43:833 Current channel 25 20:36:43:837 Device TTL 3039 s flags: 0x7 20:37:17:152 no button handler for: RWL021 ep: 0x02 cl: 0x0001 cmd: 0x0A pl[0]: 021 20:37:17:153 ZCL attribute report 0x0017880104F75F49 for cluster 0x0001, ep 0x02 20:37:43:831 Current channel 25 20:37:43:835 Device TTL 2979 s flags: 0x7 20:37:45:066 Announced to internet 20:37:45:067 discovery server date: Thu, 09 May 2019 18:37:45 GMT 20:37:45:067 local time seems to be ok 20:38:35:614 no button map for: SML001 ep: 0x02 cl: 0x0402 cmd: 0x0A pl[0]: 000 20:38:35:615 ZCL attribute report 0x0017880102103BE6 for cluster 0x0402, ep 0x02 20:38:43:843 Current channel 25 20:38:43:852 Device TTL 2919 s flags: 0x7 20:38:46:731 no button map for: SML001 ep: 0x02 cl: 0x0406 cmd: 0x0A pl[0]: 000 20:38:46:731 ZCL attribute report 0x001788010210933B for cluster 0x0406, ep 0x02 20:38:46:750 no button map for: SML001 ep: 0x02 cl: 0x0400 cmd: 0x0A pl[0]: 000 20:38:46:750 ZCL attribute report 0x001788010210933B for cluster 0x0400, ep 0x02 20:39:39:616 0xC3DE seems to be a zombie recv errors 6 20:39:39:616 LightNode removed 0x84182600000198ad 20:39:39:616 Node zombie state changed 0x84182600000198ad 20:39:43:828 Current channel 25 20:39:43:832 Device TTL 2859 s flags: 0x7 20:39:49:860 dev /dev/ttyAMA0 20:39:49:860 GW firmware version: 0x26490700 20:39:49:860 GW firmware version is up to date: 0x26490700 20:40:09:291 no button handler for: RWL020 ep: 0x02 cl: 0x0001 cmd: 0x0A pl[0]: 021 20:40:09:291 ZCL attribute report 0x00178801103E77D9 for cluster 0x0001, ep 0x02 20:40:10:454 no button map for: SML001 ep: 0x02 cl: 0x0406 cmd: 0x0A pl[0]: 000 20:40:10:454 ZCL attribute report 0x0017880102103BE6 for cluster 0x0406, ep 0x02 20:40:10:459 no button map for: SML001 ep: 0x02 cl: 0x0400 cmd: 0x0A pl[0]: 000 20:40:10:459 ZCL attribute report 0x0017880102103BE6 for cluster 0x0400, ep 0x02 20:40:25:215 0x8F4C seems to be a zombie recv errors 6 20:40:25:215 LightNode removed 0x8418260000018902 20:40:25:215 Node zombie state changed 0x8418260000018902 20:40:43:837 Current channel 25 20:40:43:848 Device TTL 2799 s flags: 0x7 20:41:18:803 no button map for: SML001 ep: 0x02 cl: 0x0402 cmd: 0x0A pl[0]: 000 20:41:18:804 ZCL attribute report 0x001788010210933B for cluster 0x0402, ep 0x02 20:41:19:871 no button handler for: RWL020 ep: 0x02 cl: 0x0001 cmd: 0x0A pl[0]: 021 20:41:19:871 ZCL attribute report 0x00178801103392BD for cluster 0x0001, ep 0x02 20:41:43:838 Current channel 25 20:41:43:847 Device TTL 2739 s flags: 0x7 20:42:17:908 no button handler for: RWL021 ep: 0x02 cl: 0x0001 cmd: 0x0A pl[0]: 021 20:42:17:908 ZCL attribute report 0x0017880104F75F49 for cluster 0x0001, ep 0x02 20:42:43:828 Current channel 25 20:42:43:832 Device TTL 2679 s flags: 0x7 20:43:35:053 no button map for: SML001 ep: 0x02 cl: 0x0402 cmd: 0x0A pl[0]: 000 20:43:35:053 ZCL attribute report 0x0017880102103BE6 for cluster 0x0402, ep 0x02 20:43:36:664 Bind response success for 0x0017880102103be6 cluster 0x0001 20:43:43:838 Current channel 25 20:43:43:847 Device TTL 2618 s flags: 0x7 20:43:46:369 no button map for: SML001 ep: 0x02 cl: 0x0406 cmd: 0x0A pl[0]: 000 20:43:46:369 ZCL attribute report 0x001788010210933B for cluster 0x0406, ep 0x02 20:43:46:374 no button map for: SML001 ep: 0x02 cl: 0x0400 cmd: 0x0A pl[0]: 000 20:43:46:374 ZCL attribute report 0x001788010210933B for cluster 0x0400, ep 0x02 20:43:47:949 Bind response success for 0x001788010210933b cluster 0x0001 20:43:49:860 dev /dev/ttyAMA0 20:43:49:860 GW firmware version: 0x26490700 20:43:49:860 GW firmware version is up to date: 0x26490700 20:43:53:047 ZCL configure reporting rsp seq: 24 0x001788010210933B for cluster 0x0001 attr 0x0021 status 0x00 20:44:43:827 Current channel 25 20:44:43:832 Device TTL 2558 s flags: 0x7 20:45:09:931 no button map for: SML001 ep: 0x02 cl: 0x0406 cmd: 0x0A pl[0]: 000
Restart Deconz addon:
[20:47:42] INFO: Start deCONZ gateway
[20:47:42] INFO: Run deCONZ OTA updater
[20:47:42] INFO: Run IKEA OTA updater
[20:47:42] INFO: Run Hass.io discovery task
{“uuid”:“xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”}
[20:47:43] INFO: Success send discovery information to Home Assistant
[20:47:43] INFO: deCONZ is setup and running
