I had to set the Devices to /dev/ttyUSB1 because i am using /dev/ttyUSB0 for my RFXCOM.
Ran the docker_compose and then add the deCONZ to the ‘Set up a new integration’ in HA
and then set the deCONZ web page http://192.168.85.5:8100/pwa/settings-gateway.html#advanced to
Allow authentification for 3rd party apps for 60 seconds. and HA had set up the config.
Rebooted HA and got
2018-07-07 18:10:57 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.deconz
2018-07-07 18:10:57 INFO (MainThread) [homeassistant.components.scene] Setting up scene.deconz
2018-07-07 18:10:57 INFO (MainThread) [homeassistant.components.light] Setting up light.deconz
So i tried to add some IKEA lights (doing a reset on the Light) using the Phoscon App web page but
nothing appears. So i stopped the docker and tried the deCONZ software.
I managed to see all my lights using the deCONZ software which means the Conbee USB is working.
Put back to the Docker and restarted but still cant see any lights from within the docker.
I keep the deConz software running on my windows pc that is running all the time for my Security Camera software. And use the Phoscon App to allow Auth for 60 seconds.
But I don’t have /want a windows 10 always on pc server.
Preferably I want to use the NUC Ubuntu that has HASSIO too and plug in the Conbee , or if that doesn’t work a raspberry pi3 and plug in the Conbee in the pi3
When I move the Conbee stiock from one hardware to another it looses all configuration?
I assume yes, so basically the way to go is to use the Conbee stick on a Laptop, move it around adding things (I have a bunch of Xiaomi sensors around the house), when finished to a backup, then insert the Conbee stick on my server that stays on 24h, restore configuration and keep it there, correct?
Sorry trying to figure out how this all works is way more difficult (to me) as imagined
Database and everything should be available on the system so you could copy them between machines if you want to, I have never tried to personally though
I don’t know why but when I attach the Conbee to the Ubuntu NUC nothing gets discovered, plus I can’t install deconz software hence difficult to debug.
When the Conbee is on my laptop it is better, although adding devices is a hit and miss (after 3-5 attempts works).
Of course I can’t keep the Conbee on the laptop 24/365 so that’s a problem.
Hope to add enough devices, so to have a strong mesh, and then move the Conbee to the NUC and add all devices there more easily.
Nevertheless it’s a pain, I have 100 devices to add…
Other issue. I have, for example a hue bulb named light.lamp.
What I did is remove it from Hue bridge, turn off from main, on again, and then add to the Conbee, I renamed it lamp.
Now in HASSIO deconz it is renamed light.lamp_2 and in HASSIO I can’t rename it in light.lamp because its taken.
How to fix this?
did you ever fix this, i seem to have the same issue using ubuntu on nuc with hassio. can see the conbee in the phoscon application but can’t discover anything
