I’m struggling with my ConBee dongle in Home Assistant… I’ve set up an automation in Home Assistant that turns on some lights on a button press. Its working fine, when it works, but sometimes, 1 out of 5 times, it just doesn’t trigger.
I looked into it and at first i thought it was the automation which was not being triggered. But then i went into the events tab in developer tools to listen for the button presses, and i noticed that not always the button press would trigger an event in Home Assistant.
I’ve tried numerous things and now i don’t know what to do anymore. I have tried different extension cords for the ConBee dongle. I’ve tried moving it all to a Synology DS918+ (plenty of power i believe), I’ve tried changing wifi channels on my local wifi to make sure there is no interference with the zigbee network. I’ve also checked the deconz integration through VNC and saw that the network was all green. There is no more than a few meters between each connected bulb, and when i do try out the remote, the dongle is right beside it. Really doesn’t matter where it is located its the same behavior. I’ve ofcourse also tried other remotes… Same result
What more can i do ?
