Nice work!
Too bad about the shares folder.
Is there a way to put this in the Hassio Add-Ons via a repository link instead of downloading it?
Because it is still a work in progress, especially with the shares folder, I’m not comfortable releasing it to a public docker registry yet. Otherwise it would be possible to download the image from the public docker registry.
As soon as it is more stable I will look into releasing it to docker. After it is in a public docker I can create a repository around it for Hass.io
Thank you for your answers. I finally got deconz connected to my hassio installation and imported two temp sensors. Funny I don´t see any of them in deconz.
You might not see the sensors in the Deconz web interface, you should be able to see them and change their names in the Phoscon app though:
Correct. Thank you.
Now I only have to wait for some other Xiaomi devices to get another challenge. The sensors seem to work very well. Now I can finally clean my house from 433-devices.
gjong thanks for the great work creating the deconz docker, I’m new to docker so I may be doing something wrong but once I had built the docker image I was unable to run due to a permission denied error. I had to add the following to the Dockerfile
RUN chmod +x start.sh
Once done worked a treat
Very new to this, but managed to get the deconz addon show up in hass.io, but then I try to Install it just try for a few seconds then this message shows up in log.
ERROR (SyncWorker_6) [hassio.docker.addon] Can’t build local/armhf-addon-conbee_deconz:1.1: ADD failed: failed to GET http://dl-cdn.alpinelinux.org/alpine/edge/testing/armhf/qt5-websockets-5.9.1-r0.apk with status 404 Not Found: I guess Its a file that is missing in the alpine index or maybe have been replaces with at newer. Anything I can do myself to solve this?
Best Regards //Richard
@gjong I’m having an issue running the hassio addon. The log is not really helpful though… Any idea where shall I start debugging it?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
[cont-init.d] 00-banner.sh: exited 267.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
s6-maximumtime: warning: child process crashed
[cont-finish.d] 99-message.sh: exited 111.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
I presume you downloaded the code from bitbucket and deployed it locally into the hassio addon directory. If so and you did so recently there might be an issue with it trying to pull in a docker image from the public registry, I had to update the configuration to prevent this. Could you try the latest version from bitbucket and see if the problem still persists after a rebuild.
Sorry for the late reply. I tested the builds locally on armv6 (pi zero) and it seems to segfault aka error 139. I’d assume this has to do with upstream image. Yet I was unable to build an image that would work although running through hassioaddons/build-env and qemu seems to produce an image. The weird thing is that the segfaults do not happen on images fetched from hassioaddons repository. Which are based of the same base images.
Hi, @gjong i installed your add-on and it works, but i can’t upgrade the firmware using the command
bash docker run --rm -it --entrypoint "/bin/bash" --privileged --device /dev/ttyAMA0:/dev/ttyAMA0:rwm local/armhf-addon-deconz GCFFlasher_internal -f /usr/share/deCONZ/firmware/deCONZ_Rpi_0x261e050 0.bin.GCF
the error is
bash: docker: No such file or directory
You will need to log into the physical machine that runs resin containers rather than hass itself: https://home-assistant.io/developers/hassio/debugging/
Something along the lines:
$ ssh [email protected] -p 22222
@peel I’m not exactly sure what is happening in your build. Does it fail during the building process with the segmentation failure or during running. I’ve not yet tested building using the build-env tools from franck, but this is something I’m going to be looking into. What I noticed from your comment is that you are on armv6 with your Pi, I haven’t tested using that hardware before so I’ll try and help you best I can without that hardware. I know the base image is based on arm32v7, so I’m not sure if that may cause issues in the image.
I usually build it on a Windows machine first locally to test the build is working and then pull the changes into my Pi3 to build it through the UI of Hass.io. So far this has worked most of the builds, and if it failed it was due to a mistake in my build script. I try to fix those as quickly as possible or my wife will get angry when she can’t control the lights for more then a few hours.
and now i can’t connect anymore to hassio.local:8123
You should do the following steps to update firmware
- stop the addon with in Your home assistant website
- SSH into the resinos machine, that is Your raspberry pi under port 2222
- then run the docker commando, this should result in the container starting that the flash was Successfully.
- after this you can Start the addon again.
Note the folder is not in Your resinos machine, but in the deconz docker image.
Some error but is it ok?
root@hassio:~# bash
root@hassio:~# docker run --rm -it --entrypoint "/bin/bash" --privileged --device /dev/ttyAMA0:/dev/ttyAMA0:rwm local/armhf-addon-deconz GCFFlasher_internal -f /usr/share/deCONZ/firmware/deCONZ_Rpi_0x261e0500.bin.GCF
rmmod: ERROR: ../libkmod/libkmod.c:514 lookup_builtin_file() could not open builtin file '/lib/modules/4.4.50/modules.builtin.bin'
rmmod: ERROR: Module ftdi_sio is not currently loaded
rmmod: ERROR: Module usbserial is not currently loaded
GCFFlasher V2_11 (c) dresden elektronik ingenieurtechnik gmbh 2017/12/10
no device specified use RaspBee (/dev/ttyAMA0)
using firmware file: /usr/share/deCONZ/firmware/deCONZ_Rpi_0x261e0500.bin.GCF
reset target
flashing 126124 bytes: |==============================|
verify: ....
SUCCESS
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.4.50/modules.dep.bin'
modprobe: FATAL: Module usbserial not found in directory /lib/modules/4.4.50
modprobe: FATAL: Module ftdi_sio not found in directory /lib/modules/4.4.50
Strange as it May sound yes the update was Successfully completed. The error are about software that is missing to flash the conbee stick. All usb related.
If you restart the addon it should state that the firmware is up to date.
I’ve just developed a new deCONZ Add-on for Hass.io (sorry @gjong, definitely not trying to step on your toes at all, I’ve had a look at your Add-on and it’s excellent work, but I’m aiming for both Conbee and RaspBee support).
- This add-on should support both Conbee and RaspBee.
- This add-on relies on a Docker Hub image (not local build) which should make installing fast, on both amd64 and armhf; and, there is a build pipeline in place to automatically update the image and add-on when a new deCONZ beta is released.
- This add-on should persist your ZigBee network data in your config folder in a subfolder called “deconz” (which will persist through version updates).
- This add-on runs on the host network and allows you to change the listening ports of the webui and websockets interfaces with config variables (should help with uPNP detection with the PWA WebUI).
I would be grateful for any beta testers since this is my first Add-on - I’ve verified that it works on my end on a RasPi 3, but more testing is definitely needed.
To install, add this repo to your Hass.io Add-On Store tab: https://github.com/marthoc/hassio-addons.
Thanks!
