Deconz halt app
Hi.
I have a Conbee II usb into a Raspberry Pi 3 running Home Assistant OS. Its plugged through an extension usb cable as recommended
Deconz complement and integration installed and working all Ok (i have this setup since 2019).
Suddenly, all the devices linked to the Conbee sttoped working. I’ve not updated nor touched anything. I have disabled automatic updates for the complements and also for the OS itself since many months ago.
Looking the Deconz complement addon i can see its stopped everytime this happens. Checking the app logs i can see there’s a problem that says “Halt app”, then sometimes the complement restarts itself (as enabled in the settings) but sometimes it just stops and is no longer starting until i do it manually. In both cases thats so annoying, because i loose the funcionality while reatarting or ill loose it until i interact.
I’m not able to see whats causing this, my knowledge its not enough, but until now I’ve tried:
Uninstall and reinstall the complement, and the HA integration.
Update the complement to the last version.
Reset the Conbee.
Change USB port.
Change Zigbee channel.
Run “ha supervisor repair” as I’ve seen it as a solution on similar issues.
None of that is solving the problem.
Here’s a part of the deconz log showing the issue:
deCONZ
09:05:33:172 sd-card cid: 035344534836344780ffffffff0161bb
09:05:34:008 DB sqlite version 3.42.0
09:05:34:014 DB PRAGMA page_count: 64
09:05:34:014 DB PRAGMA page_size: 4096
09:05:34:014 DB PRAGMA freelist_count: 0
09:05:34:014 DB file size 262144 bytes, free pages 0
09:05:34:014 DB PRAGMA user_version: 10
09:05:34:014 DB cleanup
09:05:34:024 DB create temporary views
09:05:37:289 DB skip loading sensor Puerta principal 43, handled by DDF Open/close sensor (MCCGQ01LM)
09:05:37:293 DB skip loading sensor Sensor dormitorio 39, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:294 DB skip loading sensor Puerta baño 28, handled by DDF Open/close sensor (MCCGQ11LM)
09:05:37:295 DB skip loading sensor Sensor pasillo 5, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:296 DB skip loading sensor Sensor vestidor 36, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:297 DB skip loading sensor lumi.sensor_motion.aq2 29, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:297 DB skip loading sensor Sensor salon A 31, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:298 DB skip loading sensor Sensor baño 7, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:299 DB skip loading sensor Sensor habitacion F 24, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:299 DB skip loading sensor Sensor dormitorio 38, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:300 DB skip loading sensor Sensor vestidor 37, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:301 DB skip loading sensor Sensor habitacion F 25, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:301 DB skip loading sensor Sensor pasillo 6, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:311 DB skip loading sensor Sensor baño 8, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:311 DB skip loading sensor Sensor salon A 32, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:312 DB skip loading sensor Sensor cocina 30, handled by DDF Motion sensor (RTCGQ11LM)
09:05:37:347 [INFO] - Timezone read is 'Etc/UTC'
09:05:37:348 [INFO] - Environment variable TZ found: Europe/Madrid...
09:05:37:449 Started websocket server on 0.0.0.0, port: 8081
09:05:37:485 [INFO] - Found file containing button maps. Parsing data...
09:05:37:549 [INFO] - Button maps loaded.
09:05:37:579 found node plugin: /usr/share/deCONZ/plugins/libde_rest_plugin.so - REST API Plugin
09:05:37:755 found node plugin: /usr/share/deCONZ/plugins/libstd_otau_plugin.so - STD OTAU Plugin
09:05:38:405 LightNode 1: Configuration tool 1 added
09:05:39:175 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2427219-if00 / serialno: DE2427219, ConBee II
09:05:39:769 dlg action: Read binding table
09:05:39:838 DEV found DDF for 0x00158D0006330AE1, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq01lm_openclose_sensor.json, result: 1
09:05:39:847 DEV found DDF for 0x00158D000839B896, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_rtcgqq11lm_presence_sensor.json, result: 1
09:05:39:849 DEV found DDF for 0x00158D0007C57FC1, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_mccgq11lm_openclose_sensor.json, result: 1
09:05:39:854 DEV found DDF for 0x00158D00057B3EF6, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_rtcgqq11lm_presence_sensor.json, result: 1
09:05:39:861 DEV [09:05:42] WARNING: Existing API key invalid (HTTP 404), will try to create a new one...
[09:05:42] WARNING: No API key found – trying to create a new one...
[09:05:53] INFO: API key successfully created after 1 seconds.
[09:06:33] INFO: Successfully sent discovery information to Home Assistant.
[07:07:25] INFO: Service restart after closing
[09:07:31] INFO: Starting VNC server (local - yes)...
[07:07:34] WARNING: Halt app
s6-rc: info: service legacy-services: stopping
2026/04/03 09:07:34 [notice] 147#147: signal 15 (SIGTERM) received from 144, exiting
2026/04/03 09:07:34 [notice] 455#455: exiting
I know i must ask to the vendor support, wich I’ve made, but wanted to have a chance here too because of the massive knowledge on this forum.
So, in case anyone can point some light will be much appreciated.
Thanks for your time.
A PI3 with it’s 1gb of memory is no longer recommended to run current version of HA. HA is too big.
Consider a server that has more memory.
(Why I don't recommend SBCs for running servers · GitHub)
Im not running current version of HA.
And, sorry to ask but, are you suggesting the error is caused by that ?
Please, in the future if you are not running the current version of something, tell us what version you are running so that someone can actually help you.
Since I do not have any idea what you are currently running, then I do not have an answer other than my advice in the provided link is valid with all versions of HA.
I usually don’t have any constructive help for people running months old versions of stuff, you are kind of on your own. or need to consult old posts in the forum here around the time of your version.
Im guessing you’ve run out of something if there are zero left.
Any errors showing on your welcome screen?
No, i dont see anyone there.
