Deconz migration from an Intel Mac to an M4 Mac fails
Hello dear community,
I have been migrating my Home Assistant (HASS) from my Intel MacBook Pro 2015 (VirtualBox VM) to a Mac Mini M4 (UTM VM) for several days.
Everything worked except for Deconz.
I have already tried many things, including the solutions from here: Move ConBee II to another host and reconfigure Home Assistant deCONZ integration
All devices are also displayed, both in Deconz and in Home Assistant. However, I cannot control the devices.
Here are a few excerpts from the logs:
08:47:24:341 /data/.local/share/deCONZ/config.ini exists and is writeable
08:47:24:341 /data/.local/share/deCONZ/zll.db exists and is writeable
08:47:24:345 COM: use stable device path /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466425-if00
08:47:24:351 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466425-if00 / serialno: DE2466425, ConBee II
08:47:24:351 ZCLDB init file /data/.local/share/deCONZ/zcldb.txt
Error: unable to open database "/data/.local/share/dresden-elektronik/deCONZ/zll.db": unable to open database file
08:47:59:951 SC state change failed: 38:5b:44:ff:fe:4e:a2:e2-01
08:47:59:987 Device protocol version: 0x010B
08:48:00:107 CTRL ANT_CTRL 0x03
08:48:00:161 Device protocol version: 0x010B
08:48:04:952 try to reconnect to network try=4
08:48:04:975 Device protocol version: 0x010B
08:48:05:104 CTRL ANT_CTRL 0x03
08:48:05:159 Device protocol version: 0x010B
08:48:09:948 try to reconnect to network try=5
08:48:09:978 Device protocol version: 0x010B
08:48:10:107 CTRL ANT_CTRL 0x03
08:48:10:159 Device protocol version: 0x010B
08:48:14:950 try to reconnect to network try=6
08:48:14:967 Device protocol version: 0x010B
08:48:15:131 CTRL ANT_CTRL 0x03
08:48:15:183 Device protocol version: 0x010B
08:48:15:952 SC state change failed: bc:02:6e:ff:fe:7c:e6:ba-01
08:50:08:033 0x943469FFFE250B8F seems to be a zombie recv errors 12
08:50:08:521 0x943469FFFE296495 seems to be a zombie recv errors 14
08:49:34:893 max transmit errors for node 0x54EF4410009A3C28, last seen by neighbors 130 s
08:49:34:917 max transmit errors for node 0x385B44FFFE7FA84F, last seen by neighbors 130 s
08:49:34:923 max transmit errors for node 0x54EF4410009A3C28, last seen by neighbors 130 s
08:49:34:942 max transmit errors for node 0x54EF4410009A3C28, last seen by neighbors 130 s
08:49:34:949 reconnect network done
08:49:34:966 max transmit errors for node 0x54EF4410009A3C28, last seen by neighbors 130 s
08:49:34:971 0x7CB03EAA0A0BF524 error APSDE-DATA.confirm: 0xD0 on task
08:49:34:989 max transmit errors for node 0x54EF4410009A3C28, last seen by neighbors 130 s
08:49:35:005 max transmit errors for node 0x54EF4410009A3C28, last seen by neighbors 130 s
I would be very grateful if someone could help me.
