deCONZ - Official thread
Yes but it didn’t add anything in phoscon.
Though I’m new to this, I’m happy to try debugging it with some guidance.
Did it show up in the VNC map ?
I did see an extra node on there but wasn’t sure if it was the switch or not. I’ll try it from scratch tonight and report back.
Hey I can see it on the VNC map! Can someone point me the right way to add it or request it is added as part of deconz please?
not all switches show up in deconz you need to use deconz events i guess
Thanks, I’ve tried listening for deconz_event but nothing appears when I press the buttons on the switch.
No I don’t know sorry. I did add a snartthings socket and it only appeared in the vnc map but never in phoscon. It did show up in HA though and I still use it.
They are not supported yet AFAIK
Thanks for replying. So there’s no way of adding them ourselves if we can see them in VNC map I guess. Is there any way of raising feature requests? Many thanks.
A feature request issue already exist
guys, i really like deconz, with some trial and error, i now have a perfect stable system!
now 1 annoying cosmetic issue! i DONT like the smart plug , i have some from ikea, they work good, but the dont look :slight_smile:
is there an inwall socket possible? thats supported with deconz?
something like xiaomi aqara , but then for EU market
https://nl.aliexpress.com/item/32871650876.html?ws_ab_test=searchweb0_0,searchweb201602_0_10130_10152_10151_10618_10059_10696_10084_100031_10083_10547_10624_10546_10623_10307_10868_10548_10869_10341_10065_10340_10068_10343_10342_10103_10620_10344_10325_10545_10622_10324_10621,searchweb201603_0,ppcSwitch_0&algo_pvid=905b1ddd-db96-437f-bc50-534104486b39&algo_expid=905b1ddd-db96-437f-bc50-534104486b39-12
Can Deconz Read power usage from a zigbee wallplug?
Yes you can, Innr SP120 is one example
Hmmm…I have one. There is no attribute or sensor which provides the power usage.
TPLink wlan switches can do this
Ok, I withdrow my statement and claim the opposite. Power and consumption for innr SP120
Found it finally :slight_smile:
You can check what smart plugs are supported by deconz and what values they will send.
hey all,
im really struggling with the VNC and getting that working.
running rpi4 and windos10. I can access the UI fine and add new bulbs/swtiches - no issue there
i have installed VNC but keep getting “failed” to connect with either
vnc://hassio.local:5900
or
vnc://ip:5900
any thoughts please?
Hi.
Iam new in deconz, and home assistant :slight_smile: Sorry :slight_smile:
I try to connect to conbee 2 stick, but not working.
The log:
starting version 237
[08:35:18] INFO: Starting the deCONZ gateway...
[08:35:18] INFO: Running the deCONZ OTA updater...
[08:35:18] INFO: Running the IKEA OTA updater...
[08:35:18] INFO: Running Hass.io discovery task...
{"uuid":"7e6416c8ea2243d2abb4059e5094cb88"}
[08:35:18] INFO: Success send discovery information to Home Assistant
[08:35:18] INFO: deCONZ is set up and running!
libpng warning: iCCP: known incorrect sRGB profile
08:35:19:025 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
08:35:19:167 CTRL. 3.22.008:35:19:571 COM: /dev/ttyACM0 / serialno: DE2133394
08:35:19:571 COM: --dev: /dev/ttyACM0 (ConBee II)
08:35:19:571 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
08:35:19:815 parent process bash
08:35:19:817 gw run mode: docker/hassio
08:35:19:818 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
08:35:19:820 DB sqlite version 3.22.0
08:35:19:821 DB PRAGMA page_count: 30
08:35:19:822 DB PRAGMA page_size: 4096
08:35:19:822 DB PRAGMA freelist_count: 0
08:35:19:823 DB file size 122880 bytes, free pages 0
08:35:19:823 DB PRAGMA user_version: 6
08:35:19:823 DB cleanup
08:35:19:852 DB create temporary views
08:35:19:885 don't close database yet, keep open for 900 seconds
08:35:19:886 started websocket server at port 40860
08:35:19:889 GW firmware update not supported on x86 linux headless
08:35:19:892 found node plugin: libde_rest_plugin.so - REST API Plugin
08:35:19:897 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
08:35:22:074 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
08:35:22:187 COM: /dev/ttyACM0 / serialno: DE2133394
08:35:22:187 COM: --dev: /dev/ttyACM0 (ConBee II)
This plugin does not support propagateSizeHints()
08:35:22:496 COM: /dev/ttyACM0 / serialno: DE2133394
08:35:22:500 COM: --dev: /dev/ttyACM0 (ConBee II)
08:35:22:645 COM: /dev/ttyACM0 / serialno: DE2133394
08:35:22:645 COM: --dev: /dev/ttyACM0 (ConBee II)
08:35:23:180 wait reconnect 15 seconds
08:35:23:284 COM: /dev/ttyACM0 / serialno: DE2133394
08:35:23:284 COM: --dev: /dev/ttyACM0 (ConBee II)
08:35:24:130 wait reconnect 14 seconds
08:35:24:817 discovery network reply error: Error transferring http://dresden-light.appspot.com/discover - server replied: Service Unavailable
08:35:25:080 wait reconnect 13 seconds
I connect from qnap=> virtual ubuntu=> hassio.
If i connect from windows 10… its working correctly.
Please help me.
I’m running deconz (hassio add on) on a conbee 2. I’ve updated to the most recent version of the add on and I believe also the most recent firmware and I’ve noticed that ikea bulbs no longer seem to transition their state smoothly; previously, be default, if you changed the brightness of an Ikea bulb it would smoothly and quickly change to that brightness value, but it seems now instead to immediately jump to that brightness instead. It’s very noticeable compared to the previous smooth behavior. Hue bulbs are OK. Do I need to update something or change a value somewhere?
I think I know why you see this
There is a known firmware in the Ikea smart bulbs so if you send a command to the bulb with a transition time, the bulb will appear to hang and ignore other commands during that period. Only the bri_inc = 0 command brings it out of this which is what the ikea bridge sends when you release a long held up or down button.
I have tried to find a recent reference but I am sure I read in a github report something about a workaround where they choose to change the default transition time to 0 so you avoid problems when people try to send multiple commands in sequence. You should be able to set a longer transition time but then you have to avoid sending more commands right after to same device or group.
The bug is in the Ikea bulbs. And you have to choose the work around the hurts the least. A fast on and off default is better than bulbs that do not react to e.g. color changes or will not turn on again
