deCONZ - Official thread
Click on this symbol and let deconz search. After this I’m able to login again.
I got an issue and can’t solve it.
To get everything right I followed the “Gateway ID 000000000” problem instructions.
So I uninstalled the addon and the integration, installed it again and restored the webapp with my backup.
After several restarts between and after that I started the integration process, but my integration now shows no devices.
I restarted all again, tried the “My integration shows no devices after upgrading” but it didn’t help.
Can you help me start over again.
My log shows following Error:
2019-12-21 14:11:46 WARNING (MainThread) [homeassistant.components.deconz] Invalid key for deCONZ at core-deconz.local.hass.io
Just for the record, the webapp shows all devices and I can controll them, but the integration doesn’t work. My hass.io is on 0.103.3
Doesn’t find anyting new, unfortunately.
Integration continues to work fine (VNC too), but I will not be able to add new devices.
I am running with 0.103.3.
After updating the Deconz addon to 4.1 I have an issue.
The HA seems to work but I am unable to login into the web interface.
I have the error: 403 forbidden.
What can I do to solve the issue?
Do you have IP Bans enabled?
The addon documentation has been updated to include:
Home Assistant IP Ban is triggered by the add-on. This is caused by the Phoscon frontend trying out many different URLs and locations to find devices, triggering an IP ban in the process. We are looking into a solution for this, right now, raising the number of attempts or disabling IP bans in Home Assistant, is the only workaround.
Ok, my problem is solved:
I was in the same local network (at home) as my home assistant server, but was accessing it via its global internet adress/domain, which is just a forward of port 8123. Once I tried to access the server via its internal private adress/name, everything worked…
Thanks to everyone who tried to help!
I’ve been using REST commands to call bri_inc (linear dimming), which does not work after the update.
Example:
deconz_dim_group_down:
  url: http://192.168.100.156:40850/api/123456abc/groups/{{groupid}}/action
  method: PUT
  headers:
    Content-Type: 'application/json'
  payload: '{	"bri_inc": -254, "transitiontime": 50 }'
Is there any way I can do the same through Home Assistant directly?
Thanks. It solved my issue.
Yes. Use the service deconz configure
Awesome, thanks!
Been on this most of the afternoon after upgrading Deconz. I’ve uninstalled and installed it at least 4-5 times, restating my nuc and proxmox between tasks.
The first problem, I was unable to get into the Gateway view in the deconz webUI after trying so many times, That turned out to be Safari, Chrome worked with out a problem.
I still couldn’t get the data into the deconz Integration once I had restored my backup in deconz. All was showing in the deconz webUI but not populating the hassio Integration.
The only option I had left was to delete the deconz Integration in hassio, open up the deconz web Gateway, select Advance and select ‘Authenticate app’, then I opened Configuration > Integrations in another browser and clicked on the + to add the docenz integration. This then worked for me and all is well now.
Texted too soon, Just restarted hassio and have lost the integration with deconz.
If I go to the deconz webUI, I can control the lights.
But if I go to Configuration > Integrations I can see the deconz listed but no entities, If I open up the integration, all the entities are listed but not controlable.
Any help would be welcome.
I seem to having the same issue.
If I delete the integration, restart, then re-add it (telling the gateway to allow authentication), then everything works.
As soon as I restart HA again, all the devices connected to the integration go unavailable.
At the moment my “solution” is to go through the re-adding process anytime HA needs to be restarted until a proper fix is released, and limit HA restarts where possible.
I don’t know if this is related to the issue of the addon now generating large amounts of invalid login attempts.
Anyone knows where we should raise this issue/bug? Should we report this with deCONZ owner or is this a Home Assistant issue :disappointed_relieved:
@Vasco, there are currently two open issues already:
Hi Everyone,
Im trying to get my hass.io to recognize the conbee but without any success.
It seems that the vm does not see the usb/serial device.
I have Hass.io running on a virtualbox linux machine.
in the serial port, i have entered COM3, “Host Device” and in the port/address field, i have written “COM3:”.
Any tips?
crap, just updated to 103.1 and 4.1 , also have now errors below, what do we need todo for the fix?
2019-12-22 18:20:41 WARNING (MainThread) [homeassistant.components.deconz] Invalid key for deCONZ at core-deconz.local.hass.io
2019-12-22 18:20:41 ERROR (MainThread) [homeassistant.components.deconz] Error connecting with deCONZ gateway
2019-12-22 18:23:10 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 127.0.0.1
About the “Missing entities in Deconz after updating to 4.1”.
After several hours of trying, the only thing working here is
  • delete the deCONZ integration
  • reboot HA
  • add a new integration MANUALLY ! Any auto attempt here had the same result : an empty new deCONZ integration. But when adding it with the PLUS BUTTON, things went finally ok.
So, juste before adding, you need to grant access to the add-on in PHOSCON > Gateway > Authenticate App (you got one minute).
Waiting of course for some more official solution, but if it may help for now…
Michel
Interesting what you just brought up. With all the other issues of upgrading to 4.1, I never lost any entities.
But thinking back, I never did an auto-discovery. I added/configured each entity individually and manually.
For people that my have problems with accessing the api for deCONZ because of ingress feature .
I make an work around using core-ssh , but you need to adapt.
I know people will say this is not supported.
However i have found a way to do this.
Install core-ssh
Edit sshd_config file to allow port forwarding.
core-ssh:~# cat /etc/ssh/sshd_config | grep Tcp
AllowTcpForwarding yes
core-ssh:~# ps -ef
PID USER TIME COMMAND
1 root 0:29 /dev/init – /run.sh
6 root 0:00 /usr/sbin/sshd -D -e
72 root 0:01 sshd: root@pts/0
74 root 0:00 -bash
173 root 0:00 sshd: root@pts/1
175 root 0:00 -bash
225 root 0:00 /bin/bash
240 root 0:00 ps -ef
core-ssh:~#kill -HUP 6
This way you enable SSH port forwarding.
Python sshtunnle.
https://sshtunnel.readthedocs.io/en/latest/
if you need you can use ssh tunneling form your linux box.
My example to access the api.
#!/usr/src/Python-3.7.3/python
from sshtunnel import SSHTunnelForwarder
from pprint import pprint as pp
from requests import get
import json, re, os, time
from influxdb import InfluxDBClient
conf = {
‘url’: ‘http://127.0.0.1:40850/api/’,
‘auth’ : ‘988112a4e198cc1211’,
‘ifx’ : {‘host’: ‘192.168.100.244’, ‘port’: 8086, ‘usr_’: ‘admin’, ‘pass_’: ‘PaSsWoRd’, ‘DB_’: ‘deconz_data’}
client = InfluxDBClient(host=conf[‘ifx’][‘host’], port=conf[‘ifx’][‘port’], username=conf[‘ifx’][‘usr_’], password=conf[‘ifx’][‘pass_’])
client.switch_database(conf[‘ifx’][‘DB_’])
api_ = ‘lights’
def url_ (api):
url = conf[‘url’]+conf[‘auth’]+’/’+api
headers = {‘content-type’: ‘application/json’}
response = get(url, headers=headers)
return response
with SSHTunnelForwarder(
(‘192.168.100.244’, 22),
ssh_username=“root”,
ssh_password=“StrongPassword:P”,
remote_bind_address=(‘core-deconz’, 40850),
local_bind_address=(‘0.0.0.0’, 40850)) as tunnel:
pp (url_(api_).text)
data = json.loads(url_(api_).text)
or bash:
https://www.ssh.com/ssh/tunneling/example
