I have a small request in regards to speed up controlling a custom alarm using the build-in Manual Alarm Control Panel when it is configured with a code.
At this time you have to;
- tap on the alarm component
- tap on the code-input field to set focus
- tap on the switch-to-numeric button on the soft-keyboard for entering numbers
- tap on the arm-home/arm-away button
- tap outside the alarmpanel to hide the alarm window
It would be nice if some taps can be eliminated with for instance;
- Set focus to the code-input field automatically when opening the alarm component to bring up a soft-keyboard automatically
- Option to set the field to ‘numeric’ so the soft-keyboard shows numbers right away for people that use numeric codes
- Upon successful deactivation automatically go back to main UI.
