Deepsleep not working when boot and wakeup_pin is low
i made a sensor go get a nofitication when the postman has a letter
the hardware is esp32-c3
some leds as indicators
a normal closed switch on gpio4 ( with a pulup resistor )
so gpio4 is LOW when triggered
this setup an yaml works on my testbench and when i boot the esp32 when gpio4 is HIGH
then deepsleep and awake works fine
but when i reboot the esp32 when the gpio4 is LOW , then i cant wakeup the esp32 , and stays sleeping forever
i tried the deepsleep settings , ignore , inverted , keepawake
pullup , inverted , etc…
what can i also try to do ?
kind regards
esphome:
  friendly_name: Mini
deep_sleep:
  #sleep_duration: 5min
  run_duration:
    default: 45s # enough to do ota te kunnen doen na reset
    gpio_wakeup_reason: 43s #als de pir wakker is , maak hem nog een beetje wakend
  wakeup_pin:
    number: GPIO4
    allow_other_uses: true
    inverted: False
  wakeup_pin_mode : INVERT_WAKEUP
# Create an interval to check WiFi status and control the light
interval:
  - interval: 300ms
    then:
      if:
        condition:
          not:
            wifi.connected:
        then:
          - light.toggle: integratedled
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
substitutions:
  device_name: MiniESP_C3
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "KGLmQ6JLgONOqFZJVVC2Rc6euKyHK32rX/bk7Z2VEO8="
ota:
  platform: esphome
  password: "4a2cd29cf96d59c1f4fd233eb3c0ae4f"
web_server:
  port : 80
mqtt:
  broker: !secret mqtt_broker
  username: !secret mqtt_user
  password: !secret mqtt_password
  on_connect:
    then:
      - delay: 1ms
      - light.toggle : blauw
      - mqtt.publish:
          topic : "mini/brievenbusmqtt"
          payload: "postbrief_open"
wifi:
  on_connect:
    then:
      - light.turn_on: integratedled
      - delay: 2500ms
      - light.turn_off: integratedled
  ssid: !secret wifi_ssid
  output_power: 8.5
  ap:
    ssid: "brievenbusHotspot"
    password: "kipkipkip"
captive_portal:
text_sensor:
  - platform: wifi_info
    ip_address:
    mac_address:
switch:
  - platform: restart
  - platform: gpio
    pin: 9
    internal: True
output:
  - platform: gpio
    pin: 8 #heeft de blauwe led in de button
    inverted: True
  - platform: gpio
    pin: 3 #heeft de blauwe led in de button
    inverted: False
light:
  - platform: binary
    output: led_output
  - platform: binary
    output: pcbledrood
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: "wiFi Signal dB"
    update_interval: 80s
    entity_category: "diagnostic"
    disabled_by_default: true
    internal: true
  - platform: copy # Reports the WiFi signal strength in %
    source_id: wifi_signal_db
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "%"
button:
    on_press:
      - deep_sleep.enter: deep_sleep_control
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO4
      inverted: False
    on_press:
      then:
        - delay: 300ms
        - delay: 300ms
        - delay: 300ms
        - deep_sleep.prevent: deep_sleep_control
