Default Dasboard for a user in the next version of HA
It would be really interesting to have an option in the user profile to select a default dashboard. I know there are options to do this in YAML code. But personally I find it rather complicated. An additional button under Administrator should be added to show or hide the tools.
You can already do this in your profile:
And for future reference, feature requests can be made in this forum category: Feature Requests - Home Assistant Community
But please search the category first and vote on existing ones rather than creating duplicates (which will be closed).
Thank you very much for your help. I have changed the default dashboard. But I don’t see a button to update or save the change. If I log out and come back, I get the old dashboard again. So the change can’t be saved.
Don’t log out.
Don’t you understand? I changed this dashboad to somebody else’s profile. So it had to be registered, right?
It is registered per device. Not per person.
It could have been one or the other. The devs chose per device.
Either way has pros and cons. e.g. if you make it per user then you have to create a user for every wall panel display you want a default dashboard on.
There are many WTH and Feature Requests about this.
