I wish start a script with delay.
I wish an input button on lovelace to choice delay time
Is it possible?
Hello!
Yes, you can create an input button on Lovelace to set a delay time for a script. Use an input_number entity to specify the delay, then reference it in your script. Add the input_number and script to your choiceadvantages Lovelace dashboard for easy access. This way, you can adjust the delay and start the script with a single button press.
Does this help?
I don’t undestand.
I need an helper?
