Delay sensor reading on boot
I’ve been doing some experiments with a node deep sleeping and am using an ADC sensor to let me know when it’s time to change the battery. My problem is that there seems to be a voltage sag on wake such that I get an inaccurate voltage report.
I have tried to deal with it by using update_interval, but the sensor automatically updates on boot and then again at the defined interval. The result as a rather displeasing bouncing output:
bounce
Is there a way to suppress the value of the sensor on wake so that I can delay a reading after the sag?
A simple config example of what I’m doing:
esphome:
esp32:
  board: tinypico
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: <removed>
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Test-Batt Fallback Hotspot"
    password: <removed>
  - platform: adc
    pin: 35
    name: "test batt voltage"
    update_interval: 20s
    attenuation: 11db
    filters:
      - multiply: 3.82
deep_sleep:
  run_duration: 30s
  sleep_duration: 60s
Try this:
  - platform: adc
    pin: 35
    update_interval: 1s
    attenuation: 11db
    filters:
      - multiply: 3.82
      - sliding_window_moving_average:
          window_size: 20
          send_every: 20
          send_first_at: 20
This should not send until 20 samples (1 second apart) have been taken. You will still get a slight sag but it will be a 20th of what it was (0.05v rather than 1v).
Thank you so much – this is a really clever solution, @tom_l .
I let the new config run for 12 hours and it now works perfectly. A total spread of about 50 millivolts. Amazing.
Thanks again!
I’m also trying this solution.
The battery voltage drops if the load in mA increases. This is normal behaviour (internal impedance of the battery). Therefore I guess using “min” filter would be better than moving_average, because we want to be warned about voltage too low of battery.
My setup runs for 10seconds and then deep sleep for 3 minutes. Need to figure uit the window_size, send_every and send_first in relation to update_interval.
