Delays when dimming lights from Apple Home
I have recently set up Home Assistant on a Raspberry Pi. I am also running Fibaro Home Center 3 to which I control all the light and other various devices in my home. I created an integration in Home Assistant to my Fibaro and controlling the light from Home Assistant UI works as expected.
I also installed HomeKit Bridge so I can control the light from Apple Home. However, there are delays when using the dimming function on Apple Home. I have narrowed it down to only having one device included in Home Assistant. I have also tired Setting up the HomeKit Bridge as both Bridge and Accessory to see if it made any difference.
Does anyone experience the same or have any idea of how to fix this?
