Delete stale devices
I created a device in deconz and its not working so I had to return it. Now it’s stuck as a device and several entities in home assistant. How do I remove it? I am using the latest version of hassio on rasp pi 4.
You can call the service deconz.remove_orphaned_entries
Thanks for your response. This solution is not working. Is there a file somewhere on the deconz container that I can edit to remove these orphans?
You can try to remove them from storage,but is not a recommended method
Do you know how what file I would access on storage? Or do you know how I resolve the issue with calling the service not working? I am calling it with no attributes as the only one available is optional.
You saved my day!
Thx!
