hello I have a lot of files regarding the ESPhome and I want to delete the folders from file editor but the whole folder did not delete it said first you delete the internal files and then when it get empty then you able to delete the folder so there is a way to delete the the whole folder in seconds like from the command in terminal ssh or whatever I don’t know please help me.
What a pain it is, I am also having to delete hundreds of files individually because the same issue and no one has replied to your question. Onwards I go
Try using the Samba Share Add-On so you can directly access the folder from a computer on the same network.
I will try it out, thank you.
I have been unable to get Samba share to accept a request from my pc to access the files.
