I’m having lots of problems with the data in recorder. I have purged it and it still won’t stop the duff data showing up in the sensor card graphs. I am using MariaDB. I have deleted it and reinstalled it but that hasn’t cured the problem. I have tried to go back to Homeassistant DB and that hasn’t worked either…What I have noticed is when I delete MariaDB it is still listed under the integrations section (supervisor) with three sensors disabled. Does this mean the Addon hasn’t been completely removed…I seem to be stuck in a loop…no sure what to do !!
After you delete the addon comment out the recorder db_url yaml as well.
Then restart home assistant.
This should switch you back to using the default SQL db.
Add back the addon and uncomment the db_url and restart again.
Delete the home-assistant_v2.db
file from /config.
I have done all of that and still the data is not right…As I mentioned in the thread I have noticed on the integrations page under supervisor (services) there is an entry for mariadb that isn’t removed when I remove the mariadb addon I wondered if something was being retained somewhere…I can’t delete these entries either
When I deleted the MariaDB it started Sql db and I got a file in config home-assistant_v2.db so I know the new one started, I deleted this file then reinstalled the MariaDB addon with the db_url but still its corrupt data…
