### The problem
I successfully used the Smartthings integration with my Samsung… windfree aircon, it also went quite smoothly with the Smartthings token and webhook. Nevertheless, there were 13 entities created, which do not really fit to the Samsung aircon (e.g. the entitiy fanmode is missing, which is quite crucial). What I do get is the basic info if the device is turned off or on, and some basic values like temp, humidity and volume. Besides the volume being always 100% even if I use the noise reduction mode, most painfully all the other valies keep being empty, especially the power and energy readings are always "unknown".
### What version of Home Assistant Core has the issue?
2023.6.2
### What was the last working version of Home Assistant Core?
none
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
smartthings
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/smartthings
### Diagnostics information
[home-assistant_2023-06-23T04-58-47.376Z.log](https://github.com/home-assistant/core/files/11844177/home-assistant_2023-06-23T04-58-47.376Z.log)
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
2023-06-23 06:44:27.006 DEBUG (MainThread) [pysmartapp.smartapp] 1654fa43-f7e6-f133-5eae-bc9ed326f811: EVENT received for installed app fe6856b6-c3a6-45c7-96d7-44958b4c1471.
2023-06-23 06:44:27.007 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'b3d1478f-a323-43c0-87dd-f934f2848d96', 'device_id': '4afd7c21-cebb-306a-0d8a-4e1cbcbb3503', 'component_id': 'main', 'capability': 'switch', 'attribute': 'switch', 'value': 'off', 'data': {}}
2023-06-23 06:44:27.008 DEBUG (MainThread) [homeassistant.components.smartthings.climate] Device Raumklimaanlage (4afd7c21-cebb-306a-0d8a-4e1cbcbb3503) returned an invalid supported AC mode: wind
2023-06-23 06:44:54.045 DEBUG (MainThread) [pysmartapp.smartapp] 98ceecbc-5950-2690-ddd9-44f34e3ed835: EVENT received for installed app fe6856b6-c3a6-45c7-96d7-44958b4c1471.
2023-06-23 06:44:54.047 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'b3d1478f-a323-43c0-87dd-f934f2848d96', 'device_id': '4afd7c21-cebb-306a-0d8a-4e1cbcbb3503', 'component_id': 'main', 'capability': 'switch', 'attribute': 'switch', 'value': 'on', 'data': {}}
2023-06-23 06:44:54.048 DEBUG (MainThread) [homeassistant.components.smartthings.climate] Device Raumklimaanlage (4afd7c21-cebb-306a-0d8a-4e1cbcbb3503) returned an invalid supported AC mode: wind
2023-06-23 06:45:30.960 DEBUG (MainThread) [pysmartapp.smartapp] d7dcc6ab-2309-7a71-b136-42642eac4901: EVENT received for installed app fe6856b6-c3a6-45c7-96d7-44958b4c1471.
2023-06-23 06:45:30.962 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'b3d1478f-a323-43c0-87dd-f934f2848d96', 'device_id': '4afd7c21-cebb-306a-0d8a-4e1cbcbb3503', 'component_id': 'main', 'capability': 'airConditionerFanMode', 'attribute': 'fanMode', 'value': 'low', 'data': {}}
2023-06-23 06:45:30.963 DEBUG (MainThread) [homeassistant.components.smartthings.climate] Device Raumklimaanlage (4afd7c21-cebb-306a-0d8a-4e1cbcbb3503) returned an invalid supported AC mode: wind
2023-06-23 06:55:00.786 DEBUG (MainThread) [pysmartapp.smartapp] b4a32703-11f7-71ae-a637-916da282dc65: EVENT received for installed app fe6856b6-c3a6-45c7-96d7-44958b4c1471.
2023-06-23 06:55:00.787 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'b3d1478f-a323-43c0-87dd-f934f2848d96', 'device_id': '4afd7c21-cebb-306a-0d8a-4e1cbcbb3503', 'component_id': 'main', 'capability': 'temperatureMeasurement', 'attribute': 'temperature', 'value': 26, 'data': {}}
2023-06-23 06:55:00.787 DEBUG (MainThread) [homeassistant.components.smartthings.climate] Device Raumklimaanlage (4afd7c21-cebb-306a-0d8a-4e1cbcbb3503) returned an invalid supported AC mode: wind
2023-06-23 06:55:25.210 DEBUG (MainThread) [pysmartapp.smartapp] 49ef1dc7-005c-a3ec-534f-5e76ac65a4b9: EVENT received for installed app fe6856b6-c3a6-45c7-96d7-44958b4c1471.
2023-06-23 06:55:25.211 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'b3d1478f-a323-43c0-87dd-f934f2848d96', 'device_id': '4afd7c21-cebb-306a-0d8a-4e1cbcbb3503', 'component_id': 'main', 'capability': 'airConditionerFanMode', 'attribute': 'fanMode', 'value': 'auto', 'data': {}}
2023-06-23 06:55:25.212 DEBUG (MainThread) [homeassistant.components.smartthings.climate] Device Raumklimaanlage (4afd7c21-cebb-306a-0d8a-4e1cbcbb3503) returned an invalid supported AC mode: wind
2023-06-23 06:55:47.941 DEBUG (MainThread) [pysmartapp.smartapp] 053f9262-05c6-a17d-0a42-1ec18125e469: EVENT received for installed app fe6856b6-c3a6-45c7-96d7-44958b4c1471.
2023-06-23 06:55:47.943 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'b3d1478f-a323-43c0-87dd-f934f2848d96', 'device_id': '4afd7c21-cebb-306a-0d8a-4e1cbcbb3503', 'component_id': 'main', 'capability': 'temperatureMeasurement', 'attribute': 'temperature', 'value': 27, 'data': {}}
2023-06-23 06:55:47.943 DEBUG (MainThread) [homeassistant.components.smartthings.climate] Device Raumklimaanlage (4afd7c21-cebb-306a-0d8a-4e1cbcbb3503) returned an invalid supported AC mode: wind
2023-06-23 06:56:23.544 DEBUG (MainThread) [pysmartapp.smartapp] 68225ebc-d932-2c30-5234-b8b57b971b9b: EVENT received for installed app fe6856b6-c3a6-45c7-96d7-44958b4c1471.
2023-06-23 06:56:23.546 DEBUG (MainThread) [homeassistant.components.smartthings] Push update received: {'location_id': 'b3d1478f-a323-43c0-87dd-f934f2848d96', 'device_id': '4afd7c21-cebb-306a-0d8a-4e1cbcbb3503', 'component_id': 'main', 'capability': 'temperatureMeasurement', 'attribute': 'temperature', 'value': 26, 'data': {}}
2023-06-23 06:56:23.546 DEBUG (MainThread) [homeassistant.components.smartthings.climate] Device Raumklimaanlage (4afd7c21-cebb-306a-0d8a-4e1cbcbb3503) returned an invalid supported AC mode: wind
### Additional information
_No response_
