Detected code that uses str for device registry entry_type. This is deprecated and will stop working in Home Assistant 2022.3, it should be updated to use DeviceEntryType instead. Please report this issue
since updating to 2021.12.1 coming from 2021.11.5 , i have error below
How can i troubleshoot this? i have no idea where its coming from?
thnx in advance
2021-12-13 18:58:59 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that uses str for device registry entry_type. This is deprecated and will stop working in Home Assistant 2022.3, it should be updated to use DeviceEntryType instead. Please report this issue.
Stack (most recent call last):
  File "/usr/local/lib/python3.9/runpy.py", line 197, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/local/lib/python3.9/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 331, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 318, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 121, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 629, in run_until_complete
    self.run_forever()
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 596, in run_forever
    self._run_once()
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1890, in _run_once
    handle._run()
  File "/usr/local/lib/python3.9/asyncio/events.py", line 80, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 500, in _async_add_entity
    device = device_registry.async_get_or_create(**processed_dev_info)  # type: ignore[arg-type]
  File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 360, in async_get_or_create
    report(  # type: ignore[unreachable]
  File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 74, in report
    _LOGGER.warning(msg, stack_info=True)
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
hi @petro , sorry to poke you, but i saw you ow on discord channel (beta) talking about this, but cant reply there anymore
do you have any idea how i can troubleshoot this?
thnx in advance
nm, figured it out, i had a custom component for coinbase, where enum changes were not present yet
How did you figure out what component caused it?
On luck, by looking on every custom one bye one
Ah, I have so many I was hoping there was an easy way to find out. Too bad the logs don’t specify
Yeah, indeed ,look at the specific Keyword, and use notepad++ to search in all files
What specific keyword do you mean? When I look at the raw logs I just see a lot of generic error messages leading up to this error
The word entry_type :slight_smile:
You need to look in the py files in your custom component folder, just do a search in the files
What did you use to search the files? When I use windows search it only pops up with one .js file that doesn’t even contain entry_type :man_shrugging:
With notepad++ you can search in files
Ah, you searched every file one by one? I have so many integrations, but ill just dig through them then :stuck_out_tongue:
I found out you can press ctrl+shift+F in VScode to search all files in a folder, and found the integrations that caused it!
Perfect, :slight_smile:
I have the same faultcode but the origin is HACS sow how to solve that?
class HACSDevice(Entity):
    """HACS Device class."""
    @property
    def device_info(self):
        """Return device information about HACS."""
        return {
            "identifiers": {(DOMAIN, self.unique_id)},
            "name": NAME_SHORT,
            "manufacturer": "hacs.xyz",
            "model": "",
            "sw_version": INTEGRATION_VERSION,
            "entry_type": "service",
Were you able to solve it. Just ran into the same problem… I tried to remove the apostrophes for “service”, but obviously this caused another error.
I haven’t been able to solve this error cause i don’t know how. I was hoping to get help here.
First import new DeviceEntryType:
from homeassistant.helpers.device_registry import DeviceEntryType
Then change
“entry_type” : “service”,
to
“entry_type” : DeviceEntryType.SERVICE,
No quarantee it will work with HACS, I used it for Fmi custom component.
And learn how to code Python, if you want to make changes. It helps.
