I’d like to trigger an automation when these system logs are reported by the DashCast integration. The automation will restart DashCast. Is that trigger possible?
2025-08-18 04:10:55.010 INFO (MainThread) [pychromecast.controllers] Receiver:Launching app 84912283
2025-08-18 04:10:55.010 INFO (MainThread) [homeassistant.components.script.nest_hub_2_cast] nest_hub_2_cast: Executing step call service
2025-08-18 04:10:55.011 WARNING (Thread-13) [pychromecast.socket_client] [(192.168.11.102):8009] Error writing to socket: [SSL: BAD_LENGTH] bad length (_ssl.c:2493)
2025-08-18 04:10:55.017 INFO (Thread-13) [pychromecast.controllers] Receiver:channel_disconnected
DashCast doesn’t report the error in any normal way (details here). The only reporting I can find is the logs.
You can use a command line sensor to check the log file, unfortunately that does a full scan of the file each time however - there may be more elegant solutions -
Thanks so much, @KruseLuds ! Below is the core of my solution.
When I start DashCast, I turn_on the switch.nest_hub_2_socket_state. That runs the full scan and stores the result in a small temp file. When the scan completes, HA updates the new switch state using the contents of the temp file: if the logs show a successful start then the switch becomes on, otherwise off. If the switch is off then I kill DashCast and start it again.
command_line:
- switch:
command_on: >
grep -v components.command_line home-assistant.log | grep -A 1 'nest_hub_2_cast: Executing step call service' | tail -2 > /tmp/dashcast-nest_hub_2.log
# command_off: >
# grep -v components.command_line home-assistant.log | grep -A 1 'nest_hub_2_cast: Executing step call service' | tail -2 > /tmp/dashcast-nest_hub_2.log
# Expect one line, the Executing line. If there's no Executing line then we haven't
# started DashCast since the last restart. If there's a BAD_LENGTH line then we
# started DashCast and it failed to start successfully. Either way, switch is off.
command_state: >
if [ $((`grep -E '(nest_hub_2_cast: Executing|BAD_LENGTH)' /tmp/dashcast-nest_hub_2.log | wc -l`)) != 1 ]; then exit 127; fi
scan_interval: 3600 # HA updates the switch on turn_on. Don't really need further updates.
I’m not sure if this is what you’re after, but if you set fire_event: true under the system_log integration, you can then use log entries as event triggers in automations.
Thanks @reste_narquois . This looked great but it has a big caveat. It only triggers on errors and warnings and my logs are info level.
From the docs you linked, “Errors and warnings are posted as the event system_log_event…” and “level: Either WARNING or ERROR depending on severity.” (yes, they could have been more forthcoming about “no info logs”.)
My experiments agree with the docs. I could capture errors but not info level logs.
